Datasheet Texas Instruments DS91M040TSQX/NOPB — Даташит
СерияDS91M040
МодельDS91M040TSQX/NOPB
Трансивер Quad M-LVDS 125 МГц 32-WQFN от -40 до 85
DS91M040 125 MHz Quad M-LVDS Transceiver datasheet
PDF, 1.1 Мб, Версия: M, Файл опубликован: 16 апр 2013
Pin32
Package TypeRTV
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY4500
МаркировкаM040TS
Width (мм)5
Length (мм)5
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Device TypeTransceiver
ESD HBM8 kV
FunctionTransceiver
ICC(Max)75 мА
Input SignalLVTTL,M-LVDS
No. of Rx4
No. of Tx4
Output SignalLVTTL,M-LVDS
Package GroupWQFN
Package Size: mm2:W x L32WQFN: 25 mm2: 5 x 5(WQFN) PKG
ProtocolsM-LVDS
Signaling Rate250 Mbps
  • Evaluation Modules & Boards: SMA2RJ45EVK
    SMA to RJ45 Adapter Board
  • Evaluation Modules & Boards: DS91M040EVK
    125 MHz Quad M-LVDS Transceiver Evaluation Board
  • Designing an ATCA Compliant M-LVDS Clock Distribution Network (Rev. B)
    PDF, 276 Кб, Версия: B, Файл опубликован: 26 апр 2013
    This application report provides a guide to designing ATCA compliant clock distribution networks using M-LVDS devices. The application report consists of a quick description of an ATCA synchronization clock interface, an overview of M-LVDS standard, an extensive discussion on performance of M-LVDS devices in an ATCA backplane and a set of design recommendations and rules that will assist you in bu
Серия: DS91M040 (3)
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > Buffers, Drivers/Receivers and Cross-Points
На английском языке: Datasheet Texas Instruments DS91M040TSQX/NOPB
