Datasheet Texas Instruments DS91M040 — Даташит
СерияDS91M040
Трансивер Quad M-LVDS 125 МГц
DS91M040 125 MHz Quad M-LVDS Transceiver datasheet
PDF, 1.1 Мб, Версия: M, Файл опубликован: 16 апр 2013
DS91M040TSQ/NOPBDS91M040TSQE/NOPBDS91M040TSQX/NOPB
Статус продуктаВ производствеВ производствеВ производстве
Доступность образцов у производителяДаДаНет
N123
Pin323232
Package TypeRTVRTVRTV
Industry STD TermWQFNWQFNWQFN
JEDEC CodeS-PQFP-NS-PQFP-NS-PQFP-N
Package QTY10002504500
CarrierSMALL T&RSMALL T&RLARGE T&R
МаркировкаM040TSM040TSM040TS
Width (мм)555
Length (мм)555
Thickness (мм).75.75.75
Pitch (мм).5.5.5
Max Height (мм).8.8.8
Parameters / ModelsDS91M040TSQ/NOPB
DS91M040TSQ/NOPB
DS91M040TSQE/NOPB
DS91M040TSQE/NOPB
DS91M040TSQX/NOPB
DS91M040TSQX/NOPB
Device TypeTransceiverTransceiverTransceiver
ESD HBM, kV888
FunctionTransceiverTransceiverTransceiver
ICC(Max), мА757575
Input SignalLVTTL,M-LVDSLVTTL,M-LVDSLVTTL,M-LVDS
No. of Rx444
No. of Tx444
Рабочий диапазон температур, Cот -40 до 85от -40 до 85от -40 до 85
Output SignalLVTTL,M-LVDSLVTTL,M-LVDSLVTTL,M-LVDS
Package GroupWQFNWQFNWQFN
Package Size: mm2:W x L, PKG32WQFN: 25 mm2: 5 x 5(WQFN)32WQFN: 25 mm2: 5 x 5(WQFN)32WQFN: 25 mm2: 5 x 5(WQFN)
ProtocolsM-LVDSM-LVDSM-LVDS
Signaling Rate, Mbps250250250
  • Designing an ATCA Compliant M-LVDS Clock Distribution Network (Rev. B)
    PDF, 276 Кб, Версия: B, Файл опубликован: 26 апр 2013
    This application report provides a guide to designing ATCA compliant clock distribution networks using M-LVDS devices. The application report consists of a quick description of an ATCA synchronization clock interface, an overview of M-LVDS standard, an extensive discussion on performance of M-LVDS devices in an ATCA backplane and a set of design recommendations and rules that will assist you in bu
  • Semiconductors> Interface> LVDS/M-LVDS/ECL/CML> Multipoint LVDS (MLVDS/BLVDS/LVDM)
На английском языке: Datasheet Texas Instruments DS91M040
