Datasheet Texas Instruments DS92LV0422SQE/NOPB — Даташит
СерияDS92LV0422
МодельDS92LV0422SQE/NOPB
Десериализатор Channel Link II 10–75 МГц с параллельным интерфейсом LVDS 48-WQFN от -40 до 85
DS92LV042x 10-MHz to-75 MHz Channel Link II Serializer and Deserializer With LVDS Parallel Interface datasheet
PDF, 1.6 Мб, Версия: D, Файл опубликован: 16 дек 2016
Pin48
Package TypeRHS
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаLV0422
Width (мм)7
Length (мм)7
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Clock Max75 МГц
Clock Min10 МГц
Compression Ratio4 to 1
ESD8 kV
FunctionDeserializer
Input CompatibilityCML
Output CompatibilityLVDS
Package GroupWQFN
Package Size: mm2:W x L48WQFN: 49 mm2: 7 x 7(WQFN) PKG
Parallel Bus Width4 bits
ProtocolsChannel-Link II
  • Evaluation Modules & Boards: LV04EVK01
    LV04EVK01 Evaluation Kit
  • DS15BA101 & DS15EA101 Enable Long Reach Applications for Embedded Clock SER/DES (Rev. E)
    PDF, 170 Кб, Версия: E, Файл опубликован: 29 апр 2013
    Reduction in system size, increase in system performance and savings in system cost are valuablebenefits that SER/DES devices (Serializers and Deserializers) bring to many system designers. Thesebenefits are the reason why SER/DES are integral pieces of many of today’s high-speed systems.One of the design constraints for these systems is the maximum transmission distance between a serializer
Серия: DS92LV0422 (3)
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > SerDes/Channel-Link
На английском языке: Datasheet Texas Instruments DS92LV0422SQE/NOPB
