Datasheet Texas Instruments DS92LV1021AMSAX — Даташит
СерияDS92LV1021A
МодельDS92LV1021AMSAX
16–40 МГц, 10-битный сериализатор, 28-SSOP, от –40 до 85
DS92LV1021A 16-40 MHz 10 Bit Bus LVDS Serializer datasheet
PDF, 996 Кб, Версия: G, Файл опубликован: 22 апр 2013
Pin2828
Package TypeDBDB
Industry STD TermSSOPSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY20002000
CarrierLARGE T&RLARGE T&R
МаркировкаDS92LV1021AMSA >B
Width (мм)5.35.3
Length (мм)10.210.2
Thickness (мм)1.951.95
Pitch (мм).65.65
Max Height (мм)22
Рекомендуемая замена
ReplacementDS92LV1021AMSAX/NOPB
Replacement CodeS
Approx. Price (US$)3.04 | 1ku
Data Throughput(Mb/s)400
ESD(kV)2
FunctionSerializer
ICC(Max)(mA)55
Input CompatibilityLVTTL
No. of Tx1
Operating Temperature Range(C)-40 to 85
Output CompatibilityLVDS
BLVDS
PLL Frequency(MHz)16-40
Package GroupSSOP
Package Size: mm2:W x L (PKG)28SSOP: 80 mm2: 7.8 x 10.2(SSOP)
Parallel Bus Width10
Supply Voltage(s)(V)3.3
RoHSTBD
  • DS92LV010A Bus LVDS Transcvr Ushers New Era of High-Perf Backplane Design
    PDF, 149 Кб, Файл опубликован: 15 май 2004
    Application Note 1115 DS92LV010A Bus LVDS Transceiver Ushers in a New Era of High-Per formance Backplane Design
  • DS15BA101 & DS15EA101 Enable Long Reach Applications for Embedded Clock SER/DES (Rev. E)
    PDF, 170 Кб, Версия: E, Файл опубликован: 29 апр 2013
    Reduction in system size, increase in system performance and savings in system cost are valuablebenefits that SER/DES devices (Serializers and Deserializers) bring to many system designers. Thesebenefits are the reason why SER/DES are integral pieces of many of today’s high-speed systems.One of the design constraints for these systems is the maximum transmission distance between a serializer
  • Semiconductors > Interface > Serializer, Deserializer > BLVDS/LVDS SerDes (<100 MHz)
На английском языке: Datasheet Texas Instruments DS92LV1021AMSAX
