Datasheet Texas Instruments DS92LV1224TMSA — Даташит
СерияDS92LV1224
МодельDS92LV1224TMSA
10-битный десериализатор 30–66 МГц 28-SSOP от -40 до 85
DS92LV1224 30-66 MHz 10 Bit Bus LVDS Deserializer datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 16 апр 2013
Pin2828
Package TypeDBDB
Industry STD TermSSOPSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY4747
CarrierTUBETUBE
МаркировкаMSADS92LV1224T
Width (мм)5.35.3
Length (мм)10.210.2
Thickness (мм)1.951.95
Pitch (мм).65.65
Max Height (мм)22
ESD2 kV
FunctionDeserializer
Input CompatibilityLVDS,BLVDS
Output CompatibilityLVTTL
Package GroupSSOP
Package Size: mm2:W x L28SSOP: 80 mm2: 7.8 x 10.2(SSOP) PKG
ProtocolsChannel-Link I
Supply Voltage(s)3.3 В
RoHSSee ti.com
  • How to Validate BLVDS SER/DES Signal Integrity Using an Eye Mask (Rev. A)
    PDF, 2.0 Мб, Версия: A, Файл опубликован: 26 апр 2013
    The following application report contains information that will help you validate signal quality on a BLVDS SER/DES link. How to capture an eye pattern, how to generate an eye mask, and how to validate signal quality are all explained in detail in this document.
  • DS15BA101 & DS15EA101 Enable Long Reach Applications for Embedded Clock SER/DES (Rev. E)
    PDF, 170 Кб, Версия: E, Файл опубликован: 29 апр 2013
    Reduction in system size, increase in system performance and savings in system cost are valuablebenefits that SER/DES devices (Serializers and Deserializers) bring to many system designers. Thesebenefits are the reason why SER/DES are integral pieces of many of today’s high-speed systems.One of the design constraints for these systems is the maximum transmission distance between a serializer
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > SerDes/Channel-Link
На английском языке: Datasheet Texas Instruments DS92LV1224TMSA
