Datasheet Texas Instruments DS92LV16TVHG — Даташит
СерияDS92LV16
МодельDS92LV16TVHG
Сериализатор/десериализатор 16-битной шины LVDS — 25–80 МГц 80-LQFP — от 40 до 85
DS92LV16 16-Bit Bus LVDS Serializer/Deserializer - 25 - 80 MHz datasheet
PDF, 1.3 Мб, Версия: H, Файл опубликован: 16 апр 2013
Pin8080
Package TypePNPN
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY119119
CarrierTUBETUBE
Маркировка>BDS92LV16TVHG
Width (мм)1212
Length (мм)1212
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
Рекомендуемая замена
ReplacementDS92LV16TVHG/NOPB
Replacement CodeS
ESD2.5 kV
FunctionSerDes
Input CompatibilityLVTTL,LVDS,BLVDS
Output CompatibilityLVDS,BLVDS,LVTTL
Package GroupLQFP
Package Size: mm2:W x L80LQFP: 196 mm2: 14 x 14(LQFP) PKG
ProtocolsChannel-Link I
Supply Voltage(s)3.3 В
RoHSSee ti.com
  • External Serial Interface Reduces Simultaneous Switching Output Noise in FPGAs (Rev. A)
    PDF, 8.3 Мб, Версия: A, Файл опубликован: 26 апр 2013
    This application report highlights how using external SerDes in conjunction with minimum current driveFPGA I/O can reduce FPGA’s internal noise and reap the benefits of a serial interface across the system.This may allow designers to use low end FPGAs with external SerDes to reduce cost and still have highanalog performance.
  • DS92LV16 Power Up Reset (Rev. B)
    PDF, 26 Кб, Версия: B, Файл опубликован: 26 апр 2013
    DS92LV16 date code VS39AD and later (middle two date code numbers will be ≥ 39) have a minor metallayer change to the chip’s power up reset and pull up circuitry to ensure robust start up with very slowsupply ramp rates. This change is very minor. It does not affect device functionality, performance, orreliability and requires no re-qualification.All parts sampled or purchased directly fro
  • How to Validate BLVDS SER/DES Signal Integrity Using an Eye Mask (Rev. A)
    PDF, 2.0 Мб, Версия: A, Файл опубликован: 26 апр 2013
    The following application report contains information that will help you validate signal quality on a BLVDS SER/DES link. How to capture an eye pattern, how to generate an eye mask, and how to validate signal quality are all explained in detail in this document.
  • DS15BA101 & DS15EA101 Enable Long Reach Applications for Embedded Clock SER/DES (Rev. E)
    PDF, 170 Кб, Версия: E, Файл опубликован: 29 апр 2013
    Reduction in system size, increase in system performance and savings in system cost are valuablebenefits that SER/DES devices (Serializers and Deserializers) bring to many system designers. Thesebenefits are the reason why SER/DES are integral pieces of many of today’s high-speed systems.One of the design constraints for these systems is the maximum transmission distance between a serializer
Серия: DS92LV16 (3)
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > SerDes/Channel-Link
На английском языке: Datasheet Texas Instruments DS92LV16TVHG
