Datasheet Texas Instruments DS92LV18TVVX/NOPB — Даташит
СерияDS92LV18
МодельDS92LV18TVVX/NOPB
Сериализатор/десериализатор 18-битной шины LVDS — 15–66 МГц 80-LQFP — от 40 до 85
DS92LV18 18-Bit Bus LVDS Serializer/Deserializer - 15-66 MHz datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 18 апр 2013
Pin8080
Package TypePNPN
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY10001000
CarrierLARGE T&RLARGE T&R
Маркировка>BDS92LV18TVV
Width (мм)1212
Length (мм)1212
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
ESD2 kV
FunctionSerDes
Input CompatibilityLVTTL,BLVDS
Output CompatibilityLVDS,BLVDS,LVTTL
Package GroupLQFP
Package Size: mm2:W x L80LQFP: 196 mm2: 14 x 14(LQFP) PKG
ProtocolsChannel-Link I
Supply Voltage(s)3.3 В
  • Evaluation Modules & Boards: LVDS-18B-EVK
    18-Bit Bus LVDS SERDES Evaluation Board 15-66 MHz
  • External Serial Interface Reduces Simultaneous Switching Output Noise in FPGAs (Rev. A)
    PDF, 8.3 Мб, Версия: A, Файл опубликован: 26 апр 2013
    This application report highlights how using external SerDes in conjunction with minimum current driveFPGA I/O can reduce FPGA’s internal noise and reap the benefits of a serial interface across the system.This may allow designers to use low end FPGAs with external SerDes to reduce cost and still have highanalog performance.
  • DS15BA101 & DS15EA101 Enable Long Reach Applications for Embedded Clock SER/DES (Rev. E)
    PDF, 170 Кб, Версия: E, Файл опубликован: 29 апр 2013
    Reduction in system size, increase in system performance and savings in system cost are valuablebenefits that SER/DES devices (Serializers and Deserializers) bring to many system designers. Thesebenefits are the reason why SER/DES are integral pieces of many of today’s high-speed systems.One of the design constraints for these systems is the maximum transmission distance between a serializer
Серия: DS92LV18 (2)
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > SerDes/Channel-Link
На английском языке: Datasheet Texas Instruments DS92LV18TVVX/NOPB
