Datasheet Texas Instruments DS92LV2411SQE/NOPB — Даташит
СерияDS92LV2411
МодельDS92LV2411SQE/NOPB
24-битный сериализатор Channel Link II 5–50 МГц 48-WQFN от -40 до 85
DS92LV241x 5 to 50 MHz 24-Bit Channel Link II Serializer And Deserializer datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 9 фев 2015
Pin48
Package TypeRHS
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаLV2411SQ
Width (мм)7
Length (мм)7
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Clock Max50 МГц
Clock Min5 МГц
Compression Ratio24 to 1
ESD8 kV
FunctionSerializer
Input CompatibilityLVCMOS
Output CompatibilityCML
Package GroupWQFN
Package Size: mm2:W x L48WQFN: 49 mm2: 7 x 7(WQFN) PKG
Parallel Bus Width24 bits
ProtocolsChannel-Link II
  • DS15BA101 & DS15EA101 Enable Long Reach Applications for Embedded Clock SER/DES (Rev. E)
    PDF, 170 Кб, Версия: E, Файл опубликован: 29 апр 2013
    Reduction in system size, increase in system performance and savings in system cost are valuablebenefits that SER/DES devices (Serializers and Deserializers) bring to many system designers. Thesebenefits are the reason why SER/DES are integral pieces of many of today’s high-speed systems.One of the design constraints for these systems is the maximum transmission distance between a serializer
Серия: DS92LV2411 (3)
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > SerDes/Channel-Link
На английском языке: Datasheet Texas Instruments DS92LV2411SQE/NOPB
