Datasheet Texas Instruments DS92LV2421SQE/NOPB — Даташит
Серия | DS92LV2421 |
Модель | DS92LV2421SQE/NOPB |
От 10 до 75 МГц, 24-битный сериализатор Channel-Link II 48-WQFN от -40 до 85
DS92LV242x 10-MHz to 75-MHz, 24-Bit Channel Link II Serializer And Deserializer datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 31 май 2016
Pin | 48 |
Package Type | RHS |
Industry STD Term | WQFN |
JEDEC Code | S-PQFP-N |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | LV2421SQ |
Width (мм) | 7 |
Length (мм) | 7 |
Thickness (мм) | .75 |
Pitch (мм) | .5 |
Max Height (мм) | .8 |
Mechanical Data | Скачать |
Clock Max | 75 МГц |
Clock Min | 10 МГц |
Compression Ratio | 24 to 1 |
ESD | 8 kV |
Function | Serializer |
Input Compatibility | LVCMOS |
Output Compatibility | CML |
Package Group | WQFN |
Package Size: mm2:W x L | 48WQFN: 49 mm2: 7 x 7(WQFN) PKG |
Parallel Bus Width | 24 bits |
Protocols | Channel-Link II |
Rating | Catalog |
- Evaluation Modules & Boards: LV24EVK01
LV24EVK01 Evaluation Kit
- Go the Distance: Industrial SerDes with Embedded Clock and ControlPDF, 417 Кб, Файл опубликован: 20 окт 2010
- DS15BA101 & DS15EA101 Enable Long Reach Applications for Embedded Clock SER/DES (Rev. E)PDF, 170 Кб, Версия: E, Файл опубликован: 29 апр 2013
Reduction in system size, increase in system performance and savings in system cost are valuablebenefits that SER/DES devices (Serializers and Deserializers) bring to many system designers. Thesebenefits are the reason why SER/DES are integral pieces of many of today’s high-speed systems.One of the design constraints for these systems is the maximum transmission distance between a serializer
Серия: DS92LV2421 (3)
- DS92LV2421SQ/NOPB DS92LV2421SQE/NOPB DS92LV2421SQX/NOPB
- Semiconductors > Interface > LVDS/M-LVDS/PECL > SerDes/Channel-Link
