Datasheet Texas Instruments DS92LV2422SQ/NOPB — Даташит
СерияDS92LV2422
МодельDS92LV2422SQ/NOPB
От 10 до 75 МГц, 24-битный десериализатор Channel-Link II 60-WQFN от -40 до 85
DS92LV242x 10-MHz to 75-MHz, 24-Bit Channel Link II Serializer And Deserializer datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 31 май 2016
Pin60
Package TypeNKB
Industry STD TermWQFN
JEDEC CodeS-PQSO-N
Package QTY1000
МаркировкаLV2422SQ
Width (мм)9
Length (мм)9
Thickness (мм).8
Pitch (мм).5
Max Height (мм).8
Clock Max75 МГц
Clock Min10 МГц
Compression Ratio24 to 1
ESD8 kV
FunctionDeserializer
Input CompatibilityCML
Output CompatibilityLVCMOS
Package GroupWQFN
Package Size: mm2:W x L60WQFN: 81 mm2: 9 x 9(WQFN) PKG
Parallel Bus Width24 bits
ProtocolsChannel-Link II
  • Evaluation Modules & Boards: LV24EVK01
    LV24EVK01 Evaluation Kit
  • Go the Distance: Industrial SerDes with Embedded Clock and Control
    PDF, 417 Кб, Файл опубликован: 20 окт 2010
  • DS15BA101 & DS15EA101 Enable Long Reach Applications for Embedded Clock SER/DES (Rev. E)
    PDF, 170 Кб, Версия: E, Файл опубликован: 29 апр 2013
    Reduction in system size, increase in system performance and savings in system cost are valuablebenefits that SER/DES devices (Serializers and Deserializers) bring to many system designers. Thesebenefits are the reason why SER/DES are integral pieces of many of today’s high-speed systems.One of the design constraints for these systems is the maximum transmission distance between a serializer
Серия: DS92LV2422 (3)
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > SerDes/Channel-Link
На английском языке: Datasheet Texas Instruments DS92LV2422SQ/NOPB
