Datasheet Texas Instruments DS92LV3221TVSX/NOPB — Даташит
СерияDS92LV3221
МодельDS92LV3221TVSX/NOPB
32-битный сериализатор Channel Link II 20–50 МГц 64-TQFP от -40 до 85
DS92LV3221/3222 20-50 MHz 32-Bit Channel Link II Serializer / Deserializer datasheet
PDF, 1.4 Мб, Версия: C, Файл опубликован: 16 апр 2013
Pin6464
Package TypePAGPAG
Industry STD TermTQFPTQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY10001000
CarrierLARGE T&RLARGE T&R
МаркировкаDS92LV3221TVS
Width (мм)1010
Length (мм)1010
Thickness (мм)11
Pitch (мм).5.5
Max Height (мм)1.21.2
Clock Max50 МГц
Clock Min20 МГц
Compression Ratio32 to 2
ESD4 kV
FunctionSerializer
Input CompatibilityLVCMOS
Output CompatibilityLVDS
Package GroupTQFP
Package Size: mm2:W x L64TQFP: 144 mm2: 12 x 12(TQFP) PKG
Parallel Bus Width32 bits
ProtocolsChannel-Link II
  • Evaluation Modules & Boards: LV32EVK01
    LV32EVK01 Evaluation Kit
  • Improving the Robustness of Channel Link Designs with Channel Link II Ser/Des (Rev. A)
    PDF, 62 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application note discusses how system designers are able to use Channel Link II ser/Des to improve old and new channel link designs.
  • DS15BA101 & DS15EA101 Enable Long Reach Applications for Embedded Clock SER/DES (Rev. E)
    PDF, 170 Кб, Версия: E, Файл опубликован: 29 апр 2013
    Reduction in system size, increase in system performance and savings in system cost are valuablebenefits that SER/DES devices (Serializers and Deserializers) bring to many system designers. Thesebenefits are the reason why SER/DES are integral pieces of many of today’s high-speed systems.One of the design constraints for these systems is the maximum transmission distance between a serializer
Серия: DS92LV3221 (2)
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > SerDes/Channel-Link
На английском языке: Datasheet Texas Instruments DS92LV3221TVSX/NOPB
