Линейка продуктов KEEN SIDE
Datasheet Texas Instruments DS99R124QSQX/NOPB — Даташит
СерияDS99R124Q-Q1
МодельDS99R124QSQX/NOPB
5–43 МГц, 18-битный цветной преобразователь FPD-Link II в FPD-Link 48-WQFN от -40 до 105
DS99R124Q 5 - 43 MHz 18-bit Color FPD-Link II to FPD-Link Converter datasheet
PDF, 815 Кб, Версия: D, Файл опубликован: 16 апр 2013
Pin48
Package TypeRHS
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY2500
МаркировкаDS99R124Q
Width (мм)7
Length (мм)7
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Color Depth18 bpp
DiagnosticsBIST
EMI ReductionSSCG,LVDS Outputs
FunctionDeserializer
Input CompatibilityFPD-Link II LVDS
Output CompatibilityFPD-Link LVDS
Package GroupWQFN
Package Size: mm2:W x L48WQFN: 49 mm2: 7 x 7(WQFN) PKG
Pixel Clock Min5 МГц
Pixel Clock(Max)43 МГц
RatingAutomotive
Signal ConditioningEqualizer
Special FeaturesI2C Config
Total Throughput1200 Mbps
  • Evaluation Modules & Boards: DS99R124Q-EVK
    DS99R124Q-EVK FPD-Link II to FPD-Link Converter Evaluation Kit
  • AN-1807 FPD-Link II Display SerDes Overview (Rev. B)
    PDF, 45 Кб, Версия: B, Файл опубликован: 26 апр 2013
    TI’s FPD-Link II family of embedded clock LVDS SerDes provide enhanced features, and improved signal quality over prior generations of FPD-Link SerDes devices for Display applications. FPD-Link Chipsets serialized the wide parallel RGB buses down to 4 or 5 pairs of LVDS signaling depending upon the chipset. 18-bit RGB was serialized to three LVDS data lines and a LVDS clock, while 24-bit RGB was s
  • LVDS Repeaters and Crosspoints Extend the Reach of FPD-Link II Interfaces (Rev. A)
    PDF, 101 Кб, Версия: A, Файл опубликован: 29 апр 2013
    This application note introduces Texas Instrument’s LVDS devices with built-in pre-emphasis andequalization circuits, recommends when it makes sense to employ them with the FPD-Link II SER/DES,shows how to optimally interface them to the SER/DES, and discusses distance gains that may berealized with their signal enhancing functions.
  • Extending the Reach of a FPD-Link II Interface with Cable Drivers and Equalizers (Rev. A)
    PDF, 118 Кб, Версия: A, Файл опубликован: 26 апр 2013
    TI's family of embedded clock LVDS SER/DES (FPD-link II) provides a 2-wire serial interface for displayapplications up to distances of 10 meters.
Серия: DS99R124Q-Q1 (3)
  • Semiconductors > Interface > FPD-Link SerDes > Display SerDes
На английском языке: Datasheet Texas Instruments DS99R124QSQX/NOPB
