Datasheet Texas Instruments F28M35M20B — Даташит
СерияF28M35M20B
Концертный микроконтроллер
F28M35x Concerto Microcontrollers datasheet
PDF, 2.2 Мб, Версия: I, Файл опубликован: 8 июн 2015
F28M35M20B1RFPSF28M35M20B1RFPT
N12
Pin144144
Package TypeRFPRFP
Industry STD TermHTQFPHTQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY6060
МаркировкаF28M35M20B1RFPSF28M35M20B1RFPT
Width (мм)2020
Length (мм)2020
Thickness (мм)11
Pitch (мм).5.5
Max Height (мм)1.21.2
Parameters / ModelsF28M35M20B1RFPS
F28M35M20B1RFPS
F28M35M20B1RFPT
F28M35M20B1RFPT
# of ADC Modules22
12-bit A/D, #Channels2020
ADC Channels2020
ADC Conversion Time, нс172172
ADC Resolution12-bit12-bit
ADC Sample & HoldDualDual
CAN22
CPUC28x, Cortex-M3C28x, Cortex-M3
DMA, Ch1 6-Ch DMA, 1 32-ch DMA1 6-Ch DMA, 1 32-ch DMA
EMIFYesYes
FPUYesYes
Flash, KB512512
Тактовая частота, МГц7575
GPIO6464
Generation28x + ARM Cortex M3 Concerto Series28x + ARM Cortex M3 Concerto Series
I2C33
IO Supply, В3.33.3
McBSP11
Рабочий диапазон температур, Cот -40 до 105,-40 до 125от -40 до 105,-40 до 125
PWM, Ch2424
Package GroupHTQFPHTQFP
Package Size: mm2:W x L, PKG144HTQFP: 484 mm2: 22 x 22(HTQFP)144HTQFP: 484 mm2: 22 x 22(HTQFP)
RAM, KB7272
RISC Frequency, МГц7575
RatingCatalogCatalog
SPI55
Timers3 32-Bit CPU,1 WD3 32-Bit CPU,1 WD
Total On-Chip Memory, KB584584
Total Serial Ports2 CANs,3 I2C,5 SPI,6 SCIs,1 McBSP2 CANs,3 I2C,5 SPI,6 SCIs,1 McBSP
UART66
USB11
RoHSСовместимСовместим
  • Calculating Useful Lifetimes of Embedded Processors
    PDF, 521 Кб, Файл опубликован: 11 ноя 2014
    This application report provides a methodology for calculating the useful lifetime of TI embedded processors (EP) under power when used in electronic systems. It is aimed at general engineers who wish to determine if the reliability of the TI EP meets the end system reliability requirement.
  • Calculator for CAN Bit Timing Parameters
    PDF, 37 Кб, Файл опубликован: 22 мар 2016
    Controller Area Network (CAN) nodes use user-specified timing parameters to sample the asynchronous bitstream and recover the clock. These parameters are typically based on the frequency of the available reference oscillator. There may be several options available for a given frequency, and some of them will allow a looser oscillator tolerance than others. This application report details the creat
Серия: F28M35M20B (2)
  • Semiconductors> Microcontrollers (MCU)> Performance MCUs> Control + Automation> F28M3x
На английском языке: Datasheet Texas Instruments F28M35M20B
