Datasheet Texas Instruments FDC2114RGHR — Даташит
Серия | FDC2114 |
Модель | FDC2114RGHR |
Помехоустойчивое емкостное сенсорное решение для определения приближения 16-WQFN от -40 до 125
FDC2x1x EMI-Resistant 28-Bit,12-Bit Capacitance-to-Digital Converter for Proximity and Level Sensing Applications datasheet
PDF, 1.9 Мб, Версия: A, Файл опубликован: 25 июн 2015
Pin | 16 |
Package Type | RGH |
Industry STD Term | WQFN |
JEDEC Code | S-PQFP-N |
Package QTY | 4500 |
Carrier | LARGE T&R |
Маркировка | FDC2114 |
Width (мм) | 4 |
Length (мм) | 4 |
Thickness (мм) | .75 |
Pitch (мм) | .5 |
Max Height (мм) | .8 |
Mechanical Data | Скачать |
# Input Channels | 4 |
Active Supply Current(Typ) | 2.1 мА |
Input Range(Typ) | 250000 пФ |
Interface | I2C |
Package Group | WQFN |
Package Size: mm2:W x L | 16WQFN: 16 mm2: 4 x 4(WQFN) PKG |
Pin/Package | 16WQFN |
Programmable Sampling Rate(Typ) | 40 to 13300 sps |
Rating | Catalog |
Разрешение | 12 Bits |
Shutdown Current(Typ) | 200 нА |
Special Features | EMI-resistant |
Standby Current(Typ) | 35 uA |
Напряжение питания | 3.6 Min |
- Evaluation Modules & Boards: FDC2114EVM
FDC2114 with Two Capacitive Sensors Evaluation Module
- Ground Shifting in Capacitive Sensing ApplicationsPDF, 2.2 Мб, Файл опубликован: 27 май 2016
- Capacitive Proximity Sensing Using FDC2x1yPDF, 462 Кб, Файл опубликован: 9 окт 2015
Capacitive proximity sensing is a key feature for many smart devices and equipment. In this application note, we review several important advantages of our new capacitive sensing chip FDC2x1y, which is based on an LC resonator. They include its high resolution, immunity to electro-magnetic interference (EMI), and tolerance of high offset capacitance. We also provide some guidelines in sensor desi - Power Consumption Analysis for Low Power Capacitive Sensing ApplicationsPDF, 116 Кб, Файл опубликован: 18 янв 2016
- Capacitive Sensing: Direct vs Remote Liquid Level Sensing Performance Analysis (Rev. A)PDF, 1.9 Мб, Версия: A, Файл опубликован: 24 июл 2015
- Derivative Integration Algorithm for Proximity SensingPDF, 128 Кб, Файл опубликован: 29 сен 2015
Серия: FDC2114 (2)
- FDC2114RGHR FDC2114RGHT
- Semiconductors > Sensing Products > Capacitive Sensing > Capacitance to Digital Converters
