Datasheet Texas Instruments FDC2212QDNTRQ1 — Даташит
СерияFDC2212-Q1
МодельFDC2212QDNTRQ1
2-канальное, помехоустойчивое, сертифицированное AEC-Q100, 28-битное емкостное сенсорное решение 12-WSON от -40 до 125
FDC2112-Q1, FDC2114-Q1, FDC2212-Q1, FDC2214-Q1 Multi-Channel 12-Bit or 28-Bit Capacitance-to-Digital Converter (FDC) for Capacitive Sensing datasheet
PDF, 1.9 Мб, Файл опубликован: 5 май 2016
, Proximity Sensors 2Channel, Noise-immune, AEC-Q100 qualified, 28Bit Capacitive Sensing Solution 12-WSON -40℃ to 125℃
FDC2212QDNTRQ1
330 ₽
FDC2212QDNTRQ1
330 ₽
Hi-Tech Circuit Group
FDC2212QDNTRQ1
727GS
FDC2212QDNTRQ1
Pin1212
Package TypeDNTDNT
Industry STD TermWSONWSON
JEDEC CodeS-PDSO-NS-PDSO-N
Package QTY45004500
CarrierLARGE T&RLARGE T&R
МаркировкаFDC2212Q1
Width (мм)44
Length (мм)44
Thickness (мм).75.75
Pitch (мм).5.5
Max Height (мм).8.8
# Input Channels2
Active Supply Current(Typ)2.1 мА
Input Range(Typ)250000 пФ
InterfaceI2C
Package GroupWSON
Package Size: mm2:W x LSee datasheet (WSON) PKG
Pin/Package12WSON
Programmable Sampling Rate(Typ)40 to 13300 sps
RatingAutomotive
Разрешение28 Bits
Shutdown Current(Typ)200 нА
Special FeaturesEMI-resistant
Standby Current(Typ)35 uA
Напряжение питания3.6 Min
  • Evaluation Modules & Boards: FDC2214EVM
    FDC2214 with Two Capacitive Sensors Evaluation Module
  • Ground Shifting in Capacitive Sensing Applications
    PDF, 2.2 Мб, Файл опубликован: 27 май 2016
  • Capacitive Proximity Sensing Using FDC2x1y
    PDF, 462 Кб, Файл опубликован: 9 окт 2015
    Capacitive proximity sensing is a key feature for many smart devices and equipment. In this application note, we review several important advantages of our new capacitive sensing chip FDC2x1y, which is based on an LC resonator. They include its high resolution, immunity to electro-magnetic interference (EMI), and tolerance of high offset capacitance. We also provide some guidelines in sensor desi
  • Power Consumption Analysis for Low Power Capacitive Sensing Applications
    PDF, 116 Кб, Файл опубликован: 18 янв 2016
  • Capacitive Sensing: Direct vs Remote Liquid Level Sensing Performance Analysis (Rev. A)
    PDF, 1.9 Мб, Версия: A, Файл опубликован: 24 июл 2015
  • Derivative Integration Algorithm for Proximity Sensing
    PDF, 128 Кб, Файл опубликован: 29 сен 2015
Серия: FDC2212-Q1 (2)
  • Semiconductors > Sensing Products > Capacitive Sensing > Capacitance to Digital Converters
На английском языке: Datasheet Texas Instruments FDC2212QDNTRQ1
Публикации по теме
