Datasheet Texas Instruments HDC1000YPAT — Даташит
СерияHDC1000
МодельHDC1000YPAT
Цифровой датчик влажности малой мощности, точность 3 % и встроенным датчиком температуры 8-DSBGA от -40 до 125
HDC1000 Low Power, High Accuracy Digital Humidity Sensor with Temperature Sensor datasheet
PDF, 1.4 Мб, Версия: C, Файл опубликован: 27 янв 2016
Package TypeYPA
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY250
CarrierSMALL T&R
МаркировкаE4
Thickness (мм).36
Pitch (мм).5
Max Height (мм).675
Рекомендуемая замена
ReplacementHDC1010YPAT
Replacement CodeP
  • Evaluation Modules & Boards: CC3200STK-WIFIMK
    SimpleLinkВ™ Wi-FiВ® CC3200 SensorTag
  • Evaluation Modules & Boards: NFC-DATALOGGER-EVM
    Ultralow Power Multi-sensor Data Logger with NFC Interface Evaluation Module
  • Development Kits: CC2650STK
    SimpleLinkВ™ Bluetooth low energy/Multi-standard SensorTag
  • Evaluation Modules & Boards: HDC1000EVM
    Low Power Humidity Sensor and Digital Temperature Sensor Evaluation Module
  • HDC1000 Texas Instruments Humidity Sensors
    PDF, 86 Кб, Файл опубликован: 13 июн 2014
    This application note will explain the basics of humidity sensing and some important design considerations. The application note begins with a brief description of humidity and how it is quantified. Next, some design guides to implement good system measurement are presented. Finally, different designs with HDC1000 are reviewed.
Серия: HDC1000 (2)
  • Semiconductors > Sensing Products > Humidity Sensors
На английском языке: Datasheet Texas Instruments HDC1000YPAT
