Datasheet Texas Instruments HDC1010YPAR — Даташит
СерияHDC1010
МодельHDC1010YPAR
HDC1010 Маломощный высокоточный цифровой датчик влажности с датчиком температуры 8-DSBGA от -40 до 85
HDC1010 Low Power, High Accuracy Digital Humidity Sensor with Temperature Sensor datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 29 авг 2016
34 предложений от 12 поставщиков
Датчики Влажности, HDC1010 Low Power, High Accuracy Digital Humidity Sensor with Temperature Sensor 8-DSBGA -40℃ to 85℃
HDC1010YPAR
от 41 ₽
HDC1010YPAR
61 ₽
HDC1010YPAR
727GS
HDC1010YPAR
Package TypeYPA
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY3000
Маркировка3N
Thickness (мм).36
Pitch (мм).5
Max Height (мм).675
Average Supply Current(Typ)1.2 @ 1 sample/sec uA
InterfaceI2C
Package GroupDSBGA
Relative Humidity Accuracy(Typ)В±2 %RH
Relative Humidity Operating Range(Typ)0 - 100 %RH
Напряжение питания5.5 Min
Temperature Accuracy(Typ)В±0.2 В°C
  • Evaluation Modules & Boards: HDC1010EVM
    HDC1010 Low Power Humidity and Temperature Sensor Evaluation Module
  • HDC1010 Pin FMEA
    PDF, 30 Кб, Файл опубликован: 15 дек 2016
    The HDC1010 is a digital humidity sensor with integrated temperature sensor that provides excellent measurement accuracy at very low power. The HDC1010 operates over a wide supply range, and is a low cost, low power alternative to competitive solution in a wide range of common applications.The innovative WLCSP (Wafer Level Chip Scale Package) simplifies board design with the use of an ultra-comp
  • Optimizing Placement and Routing for Humidity Sensors (Rev. A)
    PDF, 1.3 Мб, Версия: A, Файл опубликован: 6 мар 2017
    Humidity affects many properties of air, and of materials in contact with air. Water vapor is the key agentin both weather and climate, and it is an important atmospheric greenhouse gas. Humidity measurementsare used wherever there is a need to prevent condensation, corrosion, mold, warping or other spoilage ofproducts. This is highly relevant for foods, pharmaceuticals, chemicals, fuels, wo
  • AN-1112 DSBGA Wafer Level Chip Scale Package (Rev. AG)
    PDF, 13.7 Мб, Версия: AG, Файл опубликован: 12 авг 2015
Серия: HDC1010 (2)
  • Semiconductors > Sensing Products > Humidity Sensors
На английском языке: Datasheet Texas Instruments HDC1010YPAR
