Datasheet Texas Instruments HDC1010 — Даташит
СерияHDC1010
HDC1010 Маломощный, высокоточный цифровой датчик влажности с датчиком температуры
HDC1010 Low Power, High Accuracy Digital Humidity Sensor with Temperature Sensor datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 29 авг 2016
HDC1010YPARHDC1010YPAT
Доступность образцов у производителяДаНет
N12
Pin88
Package TypeYPAYPA
Industry STD TermDSBGADSBGA
JEDEC CodeR-XBGA-NR-XBGA-N
Package QTY3000250
CarrierLARGE T&RSMALL T&R
Маркировка3N3N
Thickness (мм).36.36
Pitch (мм).5.5
Max Height (мм).675.675
Parameters / ModelsHDC1010YPAR
HDC1010YPAR
HDC1010YPAT
HDC1010YPAT
Average Supply Current(Typ), uA1.2 @ 1 sample/sec1.2 @ 1 sample/sec
InterfaceI2CI2C
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Package GroupDSBGADSBGA
RatingCatalogCatalog
Relative Humidity Accuracy(Typ), %RHВ±2В±2
Relative Humidity Operating Range(Typ), %RH0 - 1000 - 100
Напряжение питания, Min5.55.5
Temperature Accuracy(Typ), В°CВ±0.2В±0.2
RoHSСовместимСовместим
  • HDC1010 Pin FMEA
    PDF, 30 Кб, Файл опубликован: 15 дек 2016
    The HDC1010 is a digital humidity sensor with integrated temperature sensor that provides excellent measurement accuracy at very low power. The HDC1010 operates over a wide supply range, and is a low cost, low power alternative to competitive solution in a wide range of common applications.The innovative WLCSP (Wafer Level Chip Scale Package) simplifies board design with the use of an ultra-comp
  • Optimizing Placement and Routing for Humidity Sensors (Rev. A)
    PDF, 1.3 Мб, Версия: A, Файл опубликован: 6 мар 2017
    Humidity affects many properties of air, and of materials in contact with air. Water vapor is the key agentin both weather and climate, and it is an important atmospheric greenhouse gas. Humidity measurementsare used wherever there is a need to prevent condensation, corrosion, mold, warping or other spoilage ofproducts. This is highly relevant for foods, pharmaceuticals, chemicals, fuels, wo
Серия: HDC1010 (2)
  • Semiconductors> Sensing Products> Humidity Sensors
На английском языке: Datasheet Texas Instruments HDC1010
