Datasheet Texas Instruments HDC1080DMBT — Даташит
СерияHDC1080
МодельHDC1080DMBT
HDC1080 Маломощный высокоточный цифровой датчик влажности с датчиком температуры 6-WSON от -40 до 125
HDC1080 Low Power, High Accuracy Digital Humidity Sensor with Temperature Sensor datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 14 янв 2016
Pin6
Package TypeDMB
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY250
CarrierSMALL T&R
Маркировка1R
Width (мм)3
Length (мм)3
Thickness (мм).75
Pitch (мм)1
Max Height (мм).8
Average Supply Current(Typ)1.2 @ 1 sample/sec uA
InterfaceI2C
Package GroupWSON
Relative Humidity Accuracy(Typ)В±2 %RH
Relative Humidity Operating Range(Typ)0 - 100 %RH
Напряжение питания5.5 Min
Temperature Accuracy(Typ)В±0.2 В°C
  • Evaluation Modules & Boards: HDC1080EVM
    HDC1080EVM Low Power Humidity and Temperature Sensor Evaluation Module
  • Optimizing Placement and Routing for Humidity Sensors (Rev. A)
    PDF, 1.3 Мб, Версия: A, Файл опубликован: 6 мар 2017
    Humidity affects many properties of air, and of materials in contact with air. Water vapor is the key agentin both weather and climate, and it is an important atmospheric greenhouse gas. Humidity measurementsare used wherever there is a need to prevent condensation, corrosion, mold, warping or other spoilage ofproducts. This is highly relevant for foods, pharmaceuticals, chemicals, fuels, wo
Серия: HDC1080 (2)
  • Semiconductors > Sensing Products > Humidity Sensors
На английском языке: Datasheet Texas Instruments HDC1080DMBT
