Клеммники KEEN SIDE
Datasheet Texas Instruments ISO120SG — Даташит
СерияISO120
МодельISO120SG
Precision Low Cost Isolation Amplifier datasheet
PDF, 187 Кб, Файл опубликован: 27 сен 2000
Pin16
Package TypeJVA
Industry STD TermCDIP SB
JEDEC CodeR-CDIP-T
Package QTY1
МаркировкаISO120SG
Width (мм)7.37
Length (мм)30.48
Thickness (мм)2.86
Pitch (мм)2.54
Max Height (мм)4.7
  • Partial Discharge Testing: What It Is and What It Means
    PDF, 24 Кб, Файл опубликован: 27 сен 2000
    What follows is information about the older test method and what it accomplished, partial discharge, how we test for it, and a comparison of similar products tested using the different methods. Some of this material appears in the ISO120/121 PDS, but bear repeating to give you the whole story.
  • Synchronization Of ISO120/121 Isolation Amplifier
    PDF, 29 Кб, Файл опубликован: 27 сен 2000
    Internal clock circuitry in the ISO120/121 precision isolation amplifier (ISO amp) can be synchronized to an external clock signal. Synchronization to an external clock can be used to eliminate beat frequencies in multichannel systems or for rejection of specific AC signals and their harmonics.
  • Boost ISO120 Bandwidth to More Than 100kHz
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    There has been considerable demand for high-bandwidth isolation amplifiers. The highest bandwidth Burr-Brown ISO amps are the ISO100 and the ISO120/121/122 family with bandwidths of about 50kHz. The ISO120/121 bandwidth can be boosted to more than 100kHz by adding gain in the feedback.
  • Single-Supply Operation of Isolation Amplifiers
    PDF, 46 Кб, Файл опубликован: 27 сен 2000
    For simplicity, many systems are designed to operate from a single external power supply. In battery powered systems such as aircraft and automotive, it's often a requirement. Isolation amplifiers such as the ISO120 and ISO122 can be easily modified for input side single-supply operation with the addition of an INA105 difference amplifier. With ISO amps, it's the isolated input side power supply w
Серия: ISO120 (3)
  • Semiconductors > Amplifiers > Special Function Amplifiers > Isolated Amplifiers
На английском языке: Datasheet Texas Instruments ISO120SG
