Datasheet Texas Instruments ISO121 — Даташит
СерияISO121
Прецизионный недорогой развязывающий усилитель
Precision Low Cost Isolation Amplifier datasheet
PDF, 187 Кб, Файл опубликован: 27 сен 2000
ISO121BGISO121G
ISO121BGISO121G
N12
Pin1616
Package TypeJVDJVD
Industry STD TermCDIP SBCDIP SB
JEDEC CodeR-CDIP-TR-CDIP-T
Package QTY11
CarrierTUBETUBE
МаркировкаISO121BGISO121G
Width (мм)15.1115.11
Length (мм)50.9350.93
Thickness (мм)2.352.35
Pitch (мм)2.542.54
Max Height (мм)4.834.83
Parameters / ModelsISO121BG
ISO121BG
ISO121G
ISO121G
Common Mode Rejection Ratio(Typ), дБ115115
Gain Non-Linearity (+/-)(Max), %0.010.01
Isolation Working Voltage VIOWM (rms), В35003500
Leakage Current at 240V/60Hz(Max), uArms0.50.5
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Package GroupCDIP SBCDIP SB
Package Size: mm2:W x L, PKGSee datasheet (CDIP SB)See datasheet (CDIP SB)
RatingCatalogCatalog
Small Signal Bandwidth(Typ), kHz6060
ISO121BGISO121G
RoHSСовместимСовместим
  • Partial Discharge Testing: What It Is and What It Means
    PDF, 24 Кб, Файл опубликован: 27 сен 2000
    What follows is information about the older test method and what it accomplished, partial discharge, how we test for it, and a comparison of similar products tested using the different methods. Some of this material appears in the ISO120/121 PDS, but bear repeating to give you the whole story.
  • Synchronization Of ISO120/121 Isolation Amplifier
    PDF, 29 Кб, Файл опубликован: 27 сен 2000
    Internal clock circuitry in the ISO120/121 precision isolation amplifier (ISO amp) can be synchronized to an external clock signal. Synchronization to an external clock can be used to eliminate beat frequencies in multichannel systems or for rejection of specific AC signals and their harmonics.
  • Boost ISO120 Bandwidth to More Than 100kHz
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    There has been considerable demand for high-bandwidth isolation amplifiers. The highest bandwidth Burr-Brown ISO amps are the ISO100 and the ISO120/121/122 family with bandwidths of about 50kHz. The ISO120/121 bandwidth can be boosted to more than 100kHz by adding gain in the feedback.
  • Single-Supply Operation of Isolation Amplifiers
    PDF, 46 Кб, Файл опубликован: 27 сен 2000
    For simplicity, many systems are designed to operate from a single external power supply. In battery powered systems such as aircraft and automotive, it's often a requirement. Isolation amplifiers such as the ISO120 and ISO122 can be easily modified for input side single-supply operation with the addition of an INA105 difference amplifier. With ISO amps, it's the isolated input side power supply w
  • Isolated RS-485 Reference Design
    PDF, 80 Кб, Файл опубликован: 28 окт 2009
    This design note presents the reference designs of isolated RS-485 nodes, using bus voltages of 3.3 V and 5 V. Various transceivers are used to satisfy the requirements for low, medium, and high data rates, as well as to accommodate the need for half- and full-duplex operation.
Серия: ISO121 (2)
  • Semiconductors> Amplifiers> Special Function Amplifiers> Isolated Amplifiers
На английском языке: Datasheet Texas Instruments ISO121
