Datasheet Texas Instruments ISO124UE4 — Даташит
СерияISO124
МодельISO124UE4
Высокоточный развязывающий усилитель 8-SOIC от -25 до 85
ISO124 Precision Lowest-Cost Isolation Amplifier datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 7 июл 2016
Pin88
Package TypeDVADVA
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY2020
CarrierTUBETUBE
МаркировкаISO124U
Width (мм)7.57.5
Length (мм)17.917.9
Thickness (мм)2.32.3
Pitch (мм)1.271.27
Max Height (мм)2.652.65
Common Mode Rejection Ratio(Typ)140 дБ
Gain Non-Linearity (+/-)(Max)0.01 %
Isolation Working Voltage VIOWM (rms)1500 В
Leakage Current at 240V/60Hz(Max)0.5 uArms
Рабочий диапазон температурот -25 до 85 C
Package Size: mm2:W x L8SOIC: 185 mm2: 10.33 x 17.9(SOIC) PKG
Small Signal Bandwidth(Typ)50 kHz
  • Simple Output Filter Eliminates ISO Amp Output Ripple And Keeps Full Bandwidth
    PDF, 186 Кб, Файл опубликован: 27 сен 2000
    The ISO120/121/122 isolation amplifiers (ISO amps) have a small (10-20mVp-p typ) residual demodulator ripple at the output. A simple filter can be added to eliminate the output ripple without decreasing the 50kHz signal bandwidth of the ISO amp.
  • Noise Sources In Applications Using Capacitive Coupled Isolated Amplifier
    PDF, 101 Кб, Файл опубликован: 27 сен 2000
    Noise is a typical problem confronting many isolation applications. Isolation products such as analog isolation amplifiers, optocouplers, transformers and digital couplers, are used in applications to transmit signals across a high voltage barrier while providing galvanic separation between two grounds.
  • Isolated RS-485 Reference Design
    PDF, 80 Кб, Файл опубликован: 28 окт 2009
    This design note presents the reference designs of isolated RS-485 nodes, using bus voltages of 3.3 V and 5 V. Various transceivers are used to satisfy the requirements for low, medium, and high data rates, as well as to accommodate the need for half- and full-duplex operation.
Серия: ISO124 (5)
  • Semiconductors > Amplifiers > Special Function Amplifiers > Isolated Amplifiers
На английском языке: Datasheet Texas Instruments ISO124UE4
