Datasheet Texas Instruments LDC1051NHRR — Даташит
СерияLDC1051
МодельLDC1051NHRR
8-разрядный индуктивно-цифровой преобразователь только Rp с SPI для приложений индуктивного измерения 16-WSON от -40 до 125
LDC1051: 8-bit Rp only Inductance-to-Digital Converter with SPI datasheet
PDF, 3.1 Мб, Файл опубликован: 13 мар 2014
Pin16
Package TypeNHR
Industry STD TermWSON
JEDEC CodeR-PDSO-N
Package QTY1000
МаркировкаLDC1051
Width (мм)4
Length (мм)5
Thickness (мм).8
Pitch (мм).5
Max Height (мм).8
  • Evaluation Modules & Boards: LDC1051EVM
    LDC1051 Inductance-to-digital converter with SPI Interface Evaluation Module
  • Using Multiple Sensors With LDC1000
    PDF, 74 Кб, Файл опубликован: 2 мар 2015
  • Configuring Inductive-to-Digital-Converters for Parallel Resistance (RP) Variati (Rev. A)
    PDF, 255 Кб, Версия: A, Файл опубликован: 1 июн 2015
    This application note reviews sensor RP configuration for LDC devices. LDC1000, LDC1041, LDC1051, LDC1312, LDC1314, LDC1612, LDC1614 are covered in this note. Clear understanding on how to set the RP_MIN and RP_MAX registers is necessary for not only RP measurements, but also for optimum L measurements. The fundamental principle of RP measurements is that magnetic fields from an LC circuit ge
  • LDC Device Selection Guide (Rev. B)
    PDF, 360 Кб, Версия: B, Файл опубликован: 21 мар 2017
  • LDC Sensor Design
    PDF, 1.0 Мб, Файл опубликован: 24 мар 2015
    Getting the best performance out of an LDC requires a sensor suitable for the measurement. This app-note covers the parameters to consider when designing a sensor for a specific application. Specific areas of focus include the physical routing characteristics of PCB based sensors, considerations for the sensor capacitor, and techniques to minimize or compensate for parasitic effects.
  • LDC1xxx LDC Target Design (Rev. A)
    PDF, 907 Кб, Версия: A, Файл опубликован: 9 май 2017
    Texas Instruments’ Inductive-to-Digital Converter (LDC) technology can accurately measure with a wide variety of target sizes, shapes, and material composition. There are several target design guidelines to maximize the effectiveness of an LDC measurement system. This application note covers the relevant factors of target design that affect inductive sensing, and provides guide
Серия: LDC1051 (3)
  • Semiconductors > Sensing Products > Inductive Sensing > Inductance to Digital Converters
На английском языке: Datasheet Texas Instruments LDC1051NHRR
