Datasheet Texas Instruments LDC1612QDNTRQ1 — Даташит
Серия | LDC1612-Q1 |
Модель | LDC1612QDNTRQ1 |
2-канальный 28-битный преобразователь индуктивности в цифровой формат, соответствующий стандарту AEC-Q100, с I2C для индуктивного измерения 12-WSON от -40 до 125
LDC1612-Q1, LDC1614-Q1 Multi-Channel 28-Bit Inductance to Digital Converter (LDC) for Inductive Sensing datasheet
PDF, 1.8 Мб, Файл опубликован: 29 апр 2016
![]() 29 предложений от 14 поставщиков IC IND TO DGTL 28B 4.08K 12WSON. Inductance-to-Digital Converter 28 bit 4.08k I²C 12-WSON (4x4). Data Acquisition - ADCs/DACs - Special... | |||
LDC1612QDNTRQ1 Texas Instruments | 44 ₽ | ||
LDC1612QDNTRQ1 Texas Instruments | 183 ₽ | ||
LDC1612QDNTRQ1 Texas Instruments | 185 ₽ | ||
Pin | 12 | 12 |
Package Type | DNT | DNT |
Industry STD Term | WSON | WSON |
JEDEC Code | S-PDSO-N | S-PDSO-N |
Package QTY | 4500 | 4500 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | LDC1612 | Q1 |
Width (мм) | 4 | 4 |
Length (мм) | 4 | 4 |
Thickness (мм) | .75 | .75 |
Pitch (мм) | .5 | .5 |
Max Height (мм) | .8 | .8 |
# Input Channels | 2 |
Active Supply Current(Typ) | 2.1 мА |
Analog Supply (V) | 2.7 Max |
Interface | I2C |
L (Inductance) Resolution | 28 Bits |
Oscillation Amplitude(Max) | 1.8 В |
Oscillation Amplitude(Min) | 0.7 В |
Package Group | WSON |
Package Size: mm2:W x L | See datasheet (WSON) PKG |
Rating | Automotive |
Response Time(Max) | N/A 1/fsensor |
Response Time(Min) | 245 1/fsensor |
Rp (Parallel Resonance Impedance) Resolution | N/A Bits |
Sensor Frequency | 1k to 10M Hz |
Sensor Rp Range(Max) | 100K Ohms |
Sensor Rp Range(Min) | 250 Ohms |
Stand-By Current(Typ) | 35 uA |
- Evaluation Modules & Boards: LDC1612EVM
LDC1612 Evaluation Module for Inductance to Digital Converter with Sample PCB Coils
- LDC1612 LDC1614 Linear Position SensingPDF, 239 Кб, Файл опубликован: 20 апр 2015
This application note explains how both approaches can be used to determine the position of a target that is moved laterally above the sensor coil and provides system design guidelines for each approach. Resolution calculations are based on the 28-bit devices LDC1612 and LDC1614, but the same principles apply to other LDCs such as LDC1000, LDC1041, LDC1312, and LDC1314. - Optimizing L Measurement Resolution for the LDC161x and LDC1101PDF, 108 Кб, Файл опубликован: 12 фев 2016
- LDC1312, LDC1314, LDC1612, LDC1614 Sensor Status MonitoringPDF, 102 Кб, Файл опубликован: 9 окт 2016
TI’s multichannel inductance-to-digital converters (LDCs) LDC1612, LDC1614, LDC1312 and LDC1314feature three different methods for reporting conversion status information including errors, warnings, andcompleted conversion results. Information is available through the data registers, the status registers, andthe INTB pin of the device. This application note explains usage and interpretation - Setting LDC1312/4, LDC1612/4, and LDC1101 Sensor Drive ConfigurationPDF, 298 Кб, Файл опубликован: 5 апр 2016
- LDC Sensor DesignPDF, 1.0 Мб, Файл опубликован: 24 мар 2015
Getting the best performance out of an LDC requires a sensor suitable for the measurement. This app-note covers the parameters to consider when designing a sensor for a specific application. Specific areas of focus include the physical routing characteristics of PCB based sensors, considerations for the sensor capacitor, and techniques to minimize or compensate for parasitic effects. - Measuring Rp of an L-C Sensor for Inductive SensingPDF, 205 Кб, Файл опубликован: 1 окт 2015
When designing an application using TI’s LDC series of inductive sensors, it is necessary to know the L-C sensor’s equivalent parallel resistance RP at the sensor’s resonant frequency. The RP value changes as the target is moved; the minimum RP occurs when the metal target is closest to the sensor. The maximum RP occurs when the target is at the farthest distance. Accordingly, both values should b
Серия: LDC1612-Q1 (2)
- LDC1612QDNTRQ1 LDC1612QDNTTQ1
- Semiconductors > Sensing Products > Inductive Sensing > Inductance to Digital Converters
