Datasheet Texas Instruments LDC2112YFDT — Даташит
СерияLDC2112
МодельLDC2112YFDT
2-канальный HMI с индуктивными сенсорными кнопками для бытовых и маломощных приложений 16-DSBGA от -40 до 85
LDC2112, LDC2114 Inductive Touch Solution for Low-Power HMI Button Applications datasheet
PDF, 1.8 Мб, Версия: B, Файл опубликован: 4 апр 2017
Pin16
Package TypeYFD
Industry STD TermDSBGA
JEDEC CodeS-XBGA-N
Package QTY250
CarrierSMALL T&R
Маркировка17M
Width (мм)2.2
Length (мм)2.2
Thickness (мм).4
Pitch (мм).4
Max Height (мм).4
# Input Channels2
Active Supply Current(Typ)3.66 мА
Analog Supply (V)1.8 Min
InterfaceGPIOs & I2C
L (Inductance) Resolution12 Bits
Oscillation Amplitude(Max)1.1 В
Oscillation Amplitude(Min)0.85 В
Package GroupDSBGA
Response Time(Max)N/A 1/fsensor
Rp (Parallel Resonance Impedance) ResolutionN/A Bits
Sensor Frequency1MHz to 30MHz Hz
Sensor Rp Range(Max)10K Ohms
Sensor Rp Range(Min)35 Ohms
Stand-By Current(Typ)5 uA
  • Evaluation Modules & Boards: LDC2114EVM
    LDC2114 1.8V 4-Channel Inductive Touch Evaluation Module
  • LDC2112/LDC2114 Inductive Touch System Design Guide
    PDF, 3.0 Мб, Файл опубликован: 2 фев 2017
    The Inductive Touch System Design Guide presents an overview of the typical sensor mechanicalstructure and sensor electrical design for human machine interface (HMI) button applications. Themechanical design chapter discusses several factors that impact button sensitivity, including metalselection, sensor geometry, sensitivity dependence on target-to-coil distance, and mechanical isolation
  • Inductive Touch Buttons for Wearables
    PDF, 386 Кб, Файл опубликован: 28 фев 2017
  • Inductive Touch - Configuring LDC2114 Touch-Button Sensitivity
    PDF, 771 Кб, Файл опубликован: 16 мар 2017
    Erroneous or unintended button presses can result in a frustrating user experience in a human machine interface (HMI). Capacitive touch buttons trigger anytime a grounded object is brought close to the button; this can often cause false or erroneous button presses. One advantage mechanical buttons have over capacitive touch buttons is that a certain amount of force must be applied on the buttons f
  • EMI Considerations for Inductive Sensing
    PDF, 151 Кб, Файл опубликован: 22 фев 2017
    This application note explains various EMI reduction techniques to help improve EMI performance for TI'sInductance-to-Digital Converters (LDC). Each section details a general technique with references to otheruseful online documents. A list of relevant EMI reduction techniques is provided for specific devices withinthe LDC family of products.
Серия: LDC2112 (4)
  • Semiconductors > Sensing Products > Inductive Sensing > Inductance to Digital Converters
На английском языке: Datasheet Texas Instruments LDC2112YFDT
