Datasheet Texas Instruments PLDC2114PWT — Даташит
СерияLDC2114
МодельPLDC2114PWT
4-канальный ЧМИ с индуктивными сенсорными кнопками для бытовых и маломощных приложений 16-TSSOP от -40 до 85
LDC2112, LDC2114 Inductive Touch Solution for Low-Power HMI Button Applications datasheet
PDF, 1.8 Мб, Версия: B, Файл опубликован: 4 апр 2017
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY250
CarrierSMALL T&R
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
# Input Channels4
Active Supply Current(Typ)(mA)3.66
Analog Supply (V)(Max)1.8
Analog Supply (V)(Min)1.8
Approx. Price (US$)1.10 | 1ku
InterfaceGPIOs & I2C
L (Inductance) Resolution(Bits)12
Operating Temperature Range(C)-40 to 85
Oscillation Amplitude(Max)(V)1.1
Oscillation Amplitude(Min)(V)0.85
Package GroupTSSOP
Package Size: mm2:W x L (PKG)See datasheet (DSBGA)
Response Time(Max)(1/fsensor)N/A
Rp (Parallel Resonance Impedance) Resolution(Bits)N/A
Sensor Frequency(Hz)1MHz to 30MHz
Sensor Rp Range(Max)(Ohms)10K
Sensor Rp Range(Min)(Ohms)35
Stand-By Current(Typ)(uA)5
RoHSTBD
  • Evaluation Modules & Boards: LDCTOUCHCOMCOILEVM
    Inductive Touch Sensor Coil Evaluation Board
  • Evaluation Modules & Boards: LDC2114EVM
    LDC2114 1.8V 4-Channel Inductive Touch Evaluation Module
  • Inductive Touch Buttons for HMIs
    PDF, 315 Кб, Файл опубликован: 9 янв 2017
    Consumer electronic device designs need to beattractive and reliable to be successful. However, mostdevices still rely on mechanical buttons which oftenemploy moving parts, gaskets, and cutouts leading tolong term reliability issues, increased costs, andinferior immunity to environmental factors. Inductivetouch buttons on the other hand enable aestheticallyattractive, gasket less, an
  • LDC2112/LDC2114 Inductive Touch System Design Guide
    PDF, 3.0 Мб, Файл опубликован: 2 фев 2017
    The Inductive Touch System Design Guide presents an overview of the typical sensor mechanicalstructure and sensor electrical design for human machine interface (HMI) button applications. Themechanical design chapter discusses several factors that impact button sensitivity, including metalselection, sensor geometry, sensitivity dependence on target-to-coil distance, and mechanical isolation
  • Inductive Touch - Configuring LDC2114 Touch-Button Sensitivity
    PDF, 771 Кб, Файл опубликован: 16 мар 2017
    Erroneous or unintended button presses can result in a frustrating user experience in a human machine interface (HMI). Capacitive touch buttons trigger anytime a grounded object is brought close to the button; this can often cause false or erroneous button presses. One advantage mechanical buttons have over capacitive touch buttons is that a certain amount of force must be applied on the buttons f
  • EMI Considerations for Inductive Sensing
    PDF, 151 Кб, Файл опубликован: 22 фев 2017
    This application note explains various EMI reduction techniques to help improve EMI performance for TI'sInductance-to-Digital Converters (LDC). Each section details a general technique with references to otheruseful online documents. A list of relevant EMI reduction techniques is provided for specific devices withinthe LDC family of products.
  • Semiconductors > Sensing Products > Inductive Sensing > Inductance to Digital Converters
На английском языке: Datasheet Texas Instruments PLDC2114PWT
