Datasheet Texas Instruments LM20323 — Даташит
СерияLM20323
Синхронный понижающий стабилизатор тока 4,5–36 В, 3 А
LM20323 36V, 3A 500 kHz Synchronous Buck Regulator datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 3 апр 2013
LM20323MH/NOPBLM20323MHE/NOPBLM20323MHX/NOPB
Статус продуктаВ производствеВ производствеВ производстве
Доступность образцов у производителяДаНетНет
N123
Pin202020
Package TypePWPPWPPWP
Industry STD TermHTSSOPHTSSOPHTSSOP
Package QTY732502500
CarrierTUBESMALL T&RLARGE T&R
Маркировка20323MH20323MH20323MH
Width (мм)4.44.44.4
Length (мм)6.56.56.5
Thickness (мм)111
Pitch (мм).65.65.65
Max Height (мм)1.21.21.2
Parameters / ModelsLM20323MH/NOPB
LM20323MH/NOPB
LM20323MHE/NOPB
LM20323MHE/NOPB
LM20323MHX/NOPB
LM20323MHX/NOPB
Control ModeCurrent ModeCurrent ModeCurrent Mode
Duty Cycle(Max), %808080
Iout(Max), A333
Iq(Typ), мА2.32.32.3
Рабочий диапазон температур, Cот -40 до 125от -40 до 125от -40 до 125
Package GroupHTSSOPHTSSOPHTSSOP
RatingCatalogCatalogCatalog
Regulated Outputs111
Special FeaturesEnable,Power Good,Pre-Bias Start-Up,Synchronous Rectification,TrackingEnable,Power Good,Pre-Bias Start-Up,Synchronous Rectification,TrackingEnable,Power Good,Pre-Bias Start-Up,Synchronous Rectification,Tracking
Switching Frequency(Max), kHz500500500
Switching Frequency(Min), kHz500500500
ТипConverterConverterConverter
Vin(Max), В363636
Vin(Min), В4.54.54.5
Vout(Max), В323232
Vout(Min), В0.80.80.8
  • AN-2077 LM20k POL Module (Rev. A)
    PDF, 1.3 Мб, Версия: A, Файл опубликован: 3 май 2013
    The LM20k is a full-featured synchronous buck switching regulator capable of driving up to 6A of loadcurrent and converting an input voltage between 2.95V and 5.5V down to an output voltage as low as0.8V. Fault protection features include cycle-by-cycle current limit, output power good, and output overvoltageprotection. The dual function soft-start/tracking pin can be used to control the sta
  • Semiconductors> Power Management> Non-isolated DC/DC Switching Regulator> Step-Down (Buck)> Buck Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments LM20323
