Datasheet Texas Instruments LM329 — Даташит
СерияLM329
Справочник по точности
LM329 Precision Reference datasheet
PDF, 486 Кб, Версия: F, Файл опубликован: 29 мар 2013
LM329DZ/NOPB
Статус продуктаНе рекомендуется для новых разработок
LM329DZ/NOPB
N1
Pin3
Package TypeLP
Industry STD TermTO-92
JEDEC CodeO-PBCY-W
Package QTY1800
МаркировкаLM329
Width (мм)4.3
Length (мм)4.3
Thickness (мм)3.6
Max Height (мм)5.34
LM329DZ/NOPB
  • AN-298 Isolation Techniques for Signal Conditioning (Rev. B)
    PDF, 685 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note provides information and examples of isolation techniques for signal conditioning.
  • IC Temp Sensor Provides Thermocouple Cold-Junction Compensation (Rev. B)
    PDF, 271 Кб, Версия: B, Файл опубликован: 23 апр 2013
    Two circuits using the LM335 for thermocouple cold-junction compensation have been described. With asingle room temperature calibration, these circuits are accurate to В±3/4В°C over a 0В°C to 70В°C temperaturerange using J or K type thermocouples. In addition, a thermocouple amplifier using an LM335 for coldjunctioncompensation has been described for which worst case error can be as low as 1В°C p
  • AN-301 Signal Conditioning for Sophisticated Transducers (Rev. B)
    PDF, 1.2 Мб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses signal conditioning and applications information for a diverse group ofsophisticated and unusual transducers.
  • AN-181 3-Terminal Regulator is Adjustable (Rev. B)
    PDF, 314 Кб, Версия: B, Файл опубликован: 5 май 2013
    Until now all of the 3-terminal power IC voltage regulators have a fixed output voltage. In spite of this limitation their ease of use low cost and full on-chip overload protection have generated wide acceptance. Now with the introduction of the LM117 it is possible to use a single regulator for any output voltage from 1.2 V to 37 V at 1.5A. Selecting close-tolerance outp
  • AN-256 Circuitry for Inexpensive Relative Humidity Measurement (Rev. B)
    PDF, 262 Кб, Версия: B, Файл опубликован: 6 май 2013
    Of all common environmental parameters humidity is perhaps the least understood and most difficult tomeasure. The most common electronic humidity detection methods albeit highly accurate are not obviousand tend to be expensive and complex (See Box). Accurate humidity measurement is vital to a number ofdiverse areas including food processing paper and lumber production pollution monitor
  • AN-263 Sine Wave Generation Techniques (Rev. C)
    PDF, 747 Кб, Версия: C, Файл опубликован: 22 апр 2013
    This application note describes the sine wave generation techniques to control frequency amplitude anddistortion levels.
  • TO-92 Packing Options / Ordering Instructions (Rev. A)
    PDF, 287 Кб, Версия: A, Файл опубликован: 23 июн 2010
  • Audio Applications of Linear Integrated Circuits
    PDF, 272 Кб, Файл опубликован: 2 май 2004
  • AN-262 Applying Dual and Quad FET Op Amps (Rev. B)
    PDF, 1.1 Мб, Версия: B, Файл опубликован: 6 май 2013
    The availability of dual and quad packaged FET op amps offers the designer all the traditional capabilitiesof FET op amps including low bias current and speed and some additional advantages. The cost-peramplifieris lower because of reduced package costs. This means that more amplifiers are available toimplement a function at a given cost making design easier. At the same time the availab
  • High Voltage Adjustable Power Supplies
    PDF, 87 Кб, Файл опубликован: 3 окт 2002
  • AN-284 Single-Supply Applications of CMOS MICRODACs (Rev. B)
    PDF, 271 Кб, Версия: B, Файл опубликован: 22 апр 2013
    CMOS data acquisition and conversion products are becoming the ideal choice for microprocessorcontrolled analog systems. The use of CMOS allows the addition of more digital logic functionality on tothe same die as the analog circuitry to minimize external parts requirements. The inherently low powerconsumption is also a big factor for battery operation and low heat generation in large scale
Серия: LM329 (1)
  • Semiconductors> Power Management> Voltage Reference> Shunt Voltage Reference
На английском языке: Datasheet Texas Instruments LM329
Публикации по теме
