Оптопары и оптореле Megawin
Datasheet Texas Instruments LM395T/NOPB — Даташит
СерияLM395
МодельLM395T/NOPB
Сверхнадежный силовой транзистор 3-TO-220 от 0 до 125
LM195/LM395 Ultra Reliable Power Transistors datasheet
PDF, 1.8 Мб, Версия: C, Файл опубликован: 7 апр 2013
Pin3
Package TypeNDE
Industry STD TermTO-220
JEDEC CodeR-MSFM-P
Package QTY45
МаркировкаLM395T
Width (мм)10.16
Length (мм)14.986
Thickness (мм)4.572
Pitch (мм)2.54
Max Height (мм)4.7
Package GroupTO-220
Package Size: mm2:W x LSee datasheet (TO-220) PKG
  • AN-173 IC Zener Eases Reference Design (Rev. B)
    PDF, 137 Кб, Версия: B, Файл опубликован: 5 май 2013
    A new IC zener with low dynamic impedance and wide operating current range significantly simplifies reference or regulator circuit design. The low dynamic impedance provides better regulation against operating current changes, easing the requirements of the biasing supply. Further, the temperature coefficient is independent of operating current, so that the LM129 can be used at
  • AN-460 LM34/LM35 Precision Monolithic Temperature Sensors (Rev. C)
    PDF, 495 Кб, Версия: C, Файл опубликован: 1 май 2013
    This application report discusses the details and uses of the Texas Instruments LM34 and LM35 asprecision temperature sensors.
  • AN-293 Control Applications of CMOS DACs
    PDF, 424 Кб, Файл опубликован: 10 май 2004
    Application Note 293 Control Applications of CMOS DACs
  • AN-181 3-Terminal Regulator is Adjustable (Rev. B)
    PDF, 314 Кб, Версия: B, Файл опубликован: 5 май 2013
    Until now all of the 3-terminal power IC voltage regulators have a fixed output voltage. In spite of this limitation their ease of use low cost and full on-chip overload protection have generated wide acceptance. Now with the introduction of the LM117 it is possible to use a single regulator for any output voltage from 1.2 V to 37 V at 1.5A. Selecting close-tolerance outp
  • General Purpose Power Supply
    PDF, 94 Кб, Файл опубликован: 3 окт 2002
  • AN-262 Applying Dual and Quad FET Op Amps (Rev. B)
    PDF, 1.1 Мб, Версия: B, Файл опубликован: 6 май 2013
    The availability of dual and quad packaged FET op amps offers the designer all the traditional capabilitiesof FET op amps including low bias current and speed and some additional advantages. The cost-peramplifieris lower because of reduced package costs. This means that more amplifiers are available toimplement a function at a given cost making design easier. At the same time the availab
  • AN-161 IC Voltage Reference has 1В ppm per Degree Drift (Rev. C)
    PDF, 275 Кб, Версия: C, Файл опубликован: 6 май 2013
    A new linear IC now provides the ultimate in highly stable voltage references. Now, a new monolithic IC the LM199, out-performs zeners and can provide a 6.9 V reference with a temperature drift of less than 1 ppm/CВ° and excellent long term stability. This new IC, uses a unique subsurface zener to achieve low noise and a highly stable breakdown. Included is an on-chip temperature stabilizer that ho
Серия: LM395 (2)
  • Semiconductors > Power Drivers > Power Transistors
На английском языке: Datasheet Texas Instruments LM395T/NOPB
