Datasheet Texas Instruments LM3S3W26 — Даташит
СерияLM3S3W26
Микроконтроллер Stellaris LM3S
Stellaris LM3S3W26 Microcontroller Data Sheet datasheet
PDF, 5.0 Мб, Версия: N, Файл опубликован: 3 июл 2014
16 предложений от 16 поставщиков
IC MCU 32BIT 32KB FLASH 64LQFP. ARM® Cortex®-M3 Stellaris® ARM® Cortex®-M3S 3000 Microcontroller IC 32-Bit 50MHz 32KB (32K x 8) FLASH...
LM3S3W26-IQR50-C0T
309 ₽
Hi-Tech Circuit Group
LM3S3W26-IQR50-C0T
LM3S3W26-IQR50-C0
МосЧип
LM3S3W26-IQR50-C1
LM3S3W26-IQR50-C5LM3S3W26-IQR50-C5T
Статус продуктаСнят с производстваСнят с производства
N12
Pin6464
Package TypePMPM
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
МаркировкаLM3S3W26IQR50
Width (мм)1010
Length (мм)1010
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
RoHSНе совместимНе совместим
  • Using AES Encryption and Decryption with Stellaris Microcontrollers (AN01251) (Rev. B)
    PDF, 113 Кб, Версия: B, Файл опубликован: 8 янв 2010
    This application note describes the following four encryption methods used with AES: Electronic code book (ECB), cipher block chaining (CBC) or chained encryption, cipher feedback (CFB), and counter (CTR). These methods are described in more detail to help you select the appropriate method(s) for your application. The encryption package described in this application note is available with full sou
  • Configuring StellarisВ® Tempest- and Firestorm-Class and MCUs W/ Pin Multiplexing (Rev. C)
    PDF, 172 Кб, Версия: C, Файл опубликован: 6 ноя 2013
    Many members of the StellarisВ® family of microcontrollers provide system designers with a great deal of control over the placement and selection of peripheral module signals that are alternate functions for GPIO signals. This application note provides an overview of the pin muxing implementation, an explanation of how a system designer defines a pin configuration, and examples of the pin confi
  • USB Certification for Stellaris-Based USB Peripherals and Embedded Host Systems
    PDF, 3.9 Мб, Файл опубликован: 7 июл 2009
    This application note describes the USB-IF certification process for a USB full-speed device and a USB full-speed embedded host system using the a Stellaris LM3S5732 microcontroller as the example.
Серия: LM3S3W26 (2)
  • Semiconductors> Microcontrollers (MCU)> Performance MCUs> Control + Automation> LM3S Cortex-M3 Series
На английском языке: Datasheet Texas Instruments LM3S3W26
