Datasheet Texas Instruments LM43600-Q1 — Даташит
СерияLM43600-Q1
Automotive Qualified SIMPLE SWITCHERВ® 3.5V to 36V, 500mA Synchronous Step-Down Voltage Converter
LM43600-Q1 3.5-V to 36-V, 0.5-A Synchronous Step-Down Voltage Converter datasheet
PDF, 2.5 Мб, Версия: B, Файл опубликован: 4 сен 2017
LM43600QPWPRQ1LM43600QPWPTQ1
Доступность образцов у производителяНетДа
N12
Pin1616
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY2000250
CarrierLARGE T&RSMALL T&R
Маркировка43600Q143600Q1
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Parameters / ModelsLM43600QPWPRQ1
LM43600QPWPRQ1
LM43600QPWPTQ1
LM43600QPWPTQ1
Control ModeCurrent ModeCurrent Mode
Duty Cycle(Max), %9999
Iout(Max), A0.50.5
Iq(Typ), мА0.0330.033
Рабочий диапазон температур, Cот -40 до 125от -40 до 125
Package GroupHTSSOPHTSSOP
RatingAutomotiveAutomotive
Regulated Outputs11
Special FeaturesEnable,Frequency Synchronization,Light Load Efficiency,Power Good,Synchronous Rectification,TrackingEnable,Frequency Synchronization,Light Load Efficiency,Power Good,Synchronous Rectification,Tracking
Switching Frequency(Max), kHz22002200
Switching Frequency(Min), kHz200200
ТипConverterConverter
Vin(Max), В3636
Vin(Min), В3.53.5
Vout(Max), В2828
Vout(Min), В11
RoHSСовместимСовместим
  • Inverting Applications Made SIMPLE With LM4600x and LM4360x (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 20 фев 2015
    Weoftenrequirepowersourceswithnegativeoutputvoltages.Therearemanydifferentwaystoproduceanegativeoutputvoltagefromapositiveinputvoltage.Oneoptionisapolarity-invertingbuck-boostconverter.Theadvantagesofthistopologyarethatitrequireslowcomponentcountandthatitcanbebuiltwithstandardhigh-sideregulato
  • Thermal Design Made Simple With LM43603 and LM46002
    PDF, 535 Кб, Файл опубликован: 15 сен 2014
    This Application Report will walk through the thermal design of power supplies using the LM43603 and LM46002.In the process we will cover common tips and approximations to speed up your design.
  • Compensation Made SIMPLE With LM4360x, LM4600x
    PDF, 457 Кб, Файл опубликован: 29 июл 2014
    Compensating a DC-DC buck converter is challenging if the designer is not familiar with the loop control theory. To achieve a stable design under all corner and adverse conditions, the user must properly compensate the regulator. While DC-DC converters with external compensation provide flexibility, they increase complexity. The LM43600/1/2/3 and LM46000/1/2 are a family of Wide VIN, fully-synchro
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
Серия: LM43600-Q1 (2)
  • Semiconductors> Power Management> Non-isolated DC/DC Switching Regulator> Step-Down (Buck)> Buck Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments LM43600-Q1
Публикации по теме
