Datasheet Texas Instruments LM4930LQ/NOPB — Даташит
СерияLM4930
МодельLM4930LQ/NOPB
Аудиоподсистема со стереонаушниками и усилителями монодинамика 44-WQFN от -30 до 85
LM4930 Audio Subsystem w/Stereo Headphone - Mono Speaker Amps datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 1 май 2013
Микросхема Усилитель звуковой частоты, Audio Amp Headphone/Microphone/Speaker 1CH Mono/2CH Stereo 1W Class-AB 44Pin LLP EP T/R
LM4930LQ/NOPB
288 ₽
SUV System
LM4930LQ/NOPB
LM4930LQ/NOPB
727GS
LM4930LQ/NOPB
Pin44
Package TypeNJN
Industry STD TermWQFN
JEDEC CodeS-PQSO-N
Package QTY250
CarrierSMALL T&R
МаркировкаL4930LQ
Width (мм)7
Length (мм)7
Thickness (мм).8
Pitch (мм).5
Max Height (мм).8
ADC Channels1
ADC SNR(Typ)75 дБ
Analog Inputs2
Analog Outputs3
DAC Channels3
DAC SNR(Typ)72 дБ
Digital Audio InterfaceI2S,PCM
Package Size: mm2:W x LSee datasheet (DSBGA),44WQFN: 49 mm2: 7 x 7(WQFN) PKG
Sampling Rate(Max)48 kHz
  • Control Port And Reset Operation SoundPlus Audio Converters and CODECs
    PDF, 77 Кб, Файл опубликован: 27 сен 2000
    This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter.
  • Configuring I2S to Generate BCLK from Codec Devices & WCLK from McBSP Port
    PDF, 105 Кб, Файл опубликован: 8 июл 2009
    This application note describes a method for interfacing the multichannel buffered serial port (McBSP) to the IВІSв„ў interface of the TLV320AIC32/33/31, theTLV320AIC3101/3104/3105/3106/3204/3254 and TLV320DAC32 devices such that the bit clock (BCLK) is generated by the audio data converter device and the word clock (WCLK) is generated by the McBSP.This type of interface is useful in applications
  • Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECs
    PDF, 291 Кб, Файл опубликован: 27 сен 2000
    This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies.
  • Using the MSP430 Launchpad as a Standalone I2C Host for Audio Products (Rev. A)
    PDF, 5.4 Мб, Версия: A, Файл опубликован: 28 окт 2013
  • Solving Enumeration Errors in USB Audio DAC and CODEC Designs
    PDF, 157 Кб, Файл опубликован: 30 окт 2009
    TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio
  • Audio Serial Interface Configurations for Audio Codecs
    PDF, 70 Кб, Файл опубликован: 22 сен 2010
    An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock
  • Out-of-Band Noise Measurement Issues for Audio Codecs
    PDF, 145 Кб, Файл опубликован: 6 дек 2006
Серия: LM4930 (2)
  • Semiconductors > Audio > Audio Converters > Audio CODEC
На английском языке: Datasheet Texas Instruments LM4930LQ/NOPB
