Datasheet Texas Instruments LM49352RL/NOPB — Даташит
СерияLM49352
МодельLM49352RL/NOPB
Подсистема монокодека аудио класса D с усилителями для наушников с заземлением, драйвером наушников и аудио DSP 36-DSBGA от -40 до 85
Mono Class D Audio Codec w/Gnd Ref Headphone Amps, Earpiece Driver, & Audio DSP datasheet
PDF, 2.5 Мб, Версия: E, Файл опубликован: 22 мар 2013
Микросхема Усилитель звуковой частоты, Audio Codec 2ADC / 2DAC 24Bit 36Pin uSMD T/R
LM49352RL/NOPB
104 ₽
LM49352RL/NOPB
271 ₽
LM49352RL/NOPB
LM49352RL/NOPB
Pin36
Package TypeYPG
Industry STD TermDSBGA
JEDEC CodeS-XBGA-N
Package QTY250
CarrierSMALL T&R
МаркировкаGL5
Thickness (мм).4
Pitch (мм).5
Max Height (мм).725
ADC Channels2
ADC SNR(Typ)97 дБ
Analog Inputs6
Analog Outputs4
DAC Channels2
DAC SNR(Typ)103 дБ
Digital Audio InterfaceI2S,PCM
Sampling Rate(Max)96 kHz
  • Control Port And Reset Operation SoundPlus Audio Converters and CODECs
    PDF, 77 Кб, Файл опубликован: 27 сен 2000
    This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter.
  • Configuring I2S to Generate BCLK from Codec Devices & WCLK from McBSP Port
    PDF, 105 Кб, Файл опубликован: 8 июл 2009
    This application note describes a method for interfacing the multichannel buffered serial port (McBSP) to the IВІSв„ў interface of the TLV320AIC32/33/31, theTLV320AIC3101/3104/3105/3106/3204/3254 and TLV320DAC32 devices such that the bit clock (BCLK) is generated by the audio data converter device and the word clock (WCLK) is generated by the McBSP.This type of interface is useful in applications
  • Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECs
    PDF, 291 Кб, Файл опубликован: 27 сен 2000
    This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies.
  • Using the MSP430 Launchpad as a Standalone I2C Host for Audio Products (Rev. A)
    PDF, 5.4 Мб, Версия: A, Файл опубликован: 28 окт 2013
  • Solving Enumeration Errors in USB Audio DAC and CODEC Designs
    PDF, 157 Кб, Файл опубликован: 30 окт 2009
    TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio
  • Audio Serial Interface Configurations for Audio Codecs
    PDF, 70 Кб, Файл опубликован: 22 сен 2010
    An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock
  • Out-of-Band Noise Measurement Issues for Audio Codecs
    PDF, 145 Кб, Файл опубликован: 6 дек 2006
Серия: LM49352 (2)
  • Semiconductors > Audio > Audio Converters > Audio CODEC
На английском языке: Datasheet Texas Instruments LM49352RL/NOPB
