Datasheet Texas Instruments LM5060MMX/NOPB — Даташит
СерияLM5060
МодельLM5060MMX/NOPB
Контроллер защиты верхнего плеча с низким током покоя 10-VSSOP от -40 до 125
LM5060 High-Side Protection Controller with Low Quiescent Current datasheet
PDF, 1.4 Мб, Версия: G, Файл опубликован: 12 ноя 2015
Pin10
Package TypeDGS
Industry STD TermVSSOP
JEDEC CodeS-PDSO-G
Package QTY3500
МаркировкаSXAB
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Pitch (мм).5
Max Height (мм)1.07
Channel(s) Controlled1
Current Limit AccuracyN/A
Current Limit Function EnabledStartup Only
Current Limit Threshold(Typ)Adjustable Ext FET=mV
Current Measurement AccuracyN/A %
Design SupportEVM
FET ProtectionN/A
Fault ResponseLatch Off
ON_OFF Control InputEN s
Package GroupVSSOP
Package Size: mm2:W x L10VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Special FeaturesNo External RSENSE
Status OutputPG/
Vabsmax_cont75 В
Vin(Max)65 В
Vin(Min)5.5 В
  • Evaluation Modules & Boards: EVMK2G
    66AK2Gx (K2G) Evaluation Module
  • Evaluation Modules & Boards: LM5060EVAL
    Evaluation Board for the LM5060
  • Surge Stopping and Reverse Voltage Protection with the LM5069
    PDF, 393 Кб, Файл опубликован: 11 апр 2013
    Many automotive and industrial applications require protection from a wide range of input supply insertion errors and voltage surges. Automotive voltage rails can exceed 40V during a load dump event, and at the same time, protection circuitry can encounter negative voltage surges below -24V during a reversal of the battery polarities. Several devices are available to block or clamp these events, h
Серия: LM5060 (2)
  • Semiconductors > Power Management > Protection, Monitoring and Hot Swap > Hot Swap Controllers (Positive, -48V)
На английском языке: Datasheet Texas Instruments LM5060MMX/NOPB
