Datasheet Texas Instruments LM5140-Q1 — Даташит
СерияLM5140-Q1
Синхронный понижающий контроллер Wide Vin с двумя частотами 2,2 МГц и низким Iq
LM5140-Q1 Wide Input Range Dual Synchronous Buck Controller datasheet
PDF, 3.1 Мб, Версия: A, Файл опубликован: 20 дек 2016
LM5140QRWGRQ1LM5140QRWGTQ1
Доступность образцов у производителяДаНет
N12
Pin4040
Package TypeRWGRWG
Industry STD TermVQFNPVQFNP
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY2500250
CarrierLARGE T&RSMALL T&R
МаркировкаRWGQ1RWGQ1
Width (мм)66
Length (мм)66
Thickness (мм).85.85
Pitch (мм).5.5
Max Height (мм).9.9
Parameters / ModelsLM5140QRWGRQ1
LM5140QRWGRQ1
LM5140QRWGTQ1
LM5140QRWGTQ1
Control ModeCurrent ModeCurrent Mode
Duty Cycle(Max), %7878
Iout(Max), A4040
Iq(Typ), мА0.0350.035
Number of Phases11
Рабочий диапазон температур, Cот -40 до 150от -40 до 150
Package GroupVQFNPVQFNP
RatingAutomotiveAutomotive
Regulated Outputs22
Special FeaturesAdjustable Current Limit,Enable,Frequency Synchronization,Light Load Efficiency,Phase Interleaving,Power Good,Synchronous RectificationAdjustable Current Limit,Enable,Frequency Synchronization,Light Load Efficiency,Phase Interleaving,Power Good,Synchronous Rectification
Switching Frequency(Max), kHz26002600
Switching Frequency(Min), kHz350350
ТипControllerController
Vin(Max), В6565
Vin(Min), В3.83.8
Vout(Max), В1515
Vout(Min), В1.51.5
RoHSСовместимСовместим
  • Maintaining Output Voltage Regulation During Automotive Cold-Crank with LM5140
    PDF, 253 Кб, Файл опубликован: 13 янв 2016
    Designing electronics to operate from a 12-V car supply is challenging. The 12-V battery supply voltage can range from 9-16V under normal operation depending on charge and load variation. However, the transient battery voltage range can be much wider. One of these conditions is cold-crank, cold-crank occurs when the battery is trying to energize the starter-motor circuits on th
  • Designing the front-end DC/DC conversion stage to withstand automotive transient
    PDF, 336 Кб, Файл опубликован: 18 янв 2017
  • Reduce buck-converter EMI and voltage stress by minimizing inductive parasitics
    PDF, 926 Кб, Файл опубликован: 21 июл 2016
Серия: LM5140-Q1 (2)
  • Semiconductors> Power Management> Non-isolated DC/DC Switching Regulator> Step-Down (Buck)> Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments LM5140-Q1
