Datasheet Texas Instruments LM64 — Даташит
| Серия | LM64 |
В±1В°C Remote Diode Temperature Sensor with PWM Fan Control and 5 GPIO's
LM64 +-1C Remote Diode Temp Sensor w/PWM Fan Cntrl & 5 GPIO's datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 22 мар 2013
Купить LM64CILQ-F/NOPB на РадиоЛоцман.Цены — от 124 до 15 605 ₽21 предложений от 17 поставщиков Датчик температуры, Fan Control, Temp Monitor 0°C ~ 85℃, 25℃ ~ 140℃ Internal and External Sensor 2-Wire SMBus Output 24-WQFN (4x5)... | |||
| LM64CILQ-F/NOPB Texas Instruments | 124 ₽ | ||
| LM64CILQ-F/NOPB Texas Instruments | 196 ₽ | ||
| LM64CILQ-F/NOPB Texas Instruments | от 655 ₽ | ||
| LM64CILQ-F/NOPB Texas Instruments | 15 605 ₽ | ||
| LM64CILQ-F/NOPB | |
| LM64CILQ-F/NOPB | |
| N | 1 |
| Pin | 24 |
| Package Type | NHW |
| Industry STD Term | WQFN |
| JEDEC Code | R-PQSO-N |
| Package QTY | 1000 |
| Carrier | SMALL T&R |
| Маркировка | 64CILQF |
| Width (мм) | 4 |
| Length (мм) | 5 |
| Thickness (мм) | .8 |
| Pitch (мм) | .5 |
| Max Height (мм) | .8 |
| Mechanical Data | Скачать |
| Parameters / Models | LM64CILQ-F/NOPB![]() |
| Fan Control Method | Lookup Table |
| Fan Control Output, s | 1 PWM |
| Fan Speed Inputs | 1 |
| Fan Speed Measurement Accuracy, % | 10 |
| GPIOs | 5 GPIO, 5 GPD, ALERT, TACH, PWM, TCRIT |
| Interface Type | SMBus |
| Interrupt Outputs, Count | 1 |
| No. of Temperature Sensors | 2 |
| Рабочий диапазон температур, C | от 0 до 125 |
| PWM Duty Cycle Resolution, bits | 6 |
| Package Group | WQFN |
| Package Size: mm2:W x L, PKG | 24WQFN: 20 mm2: 4 x 5(WQFN) |
| Собственный ток потребления, мА | 1.1 |
| Rating | Catalog |
| Supply Current(Max), мА | 2 |
| Supply Voltage(Max), В | 3.6 |
| Supply Voltage(Min), В | 3 |
| Temperature Sensor Accuracy, C | 1C max for 120C to 140C, 3C max for 25C to 120C |
| Temperature Sensor Resolution, C | 0.125 |
| TruTherm, TM | No |
| LM64CILQ-F/NOPB | |
Серия: LM64 (1)
- Semiconductors> Sensing Products> Monitoring & Fan Control
