Datasheet Texas Instruments LM78L15 — Даташит
СерияLM78L15
Линейный стабилизатор с фиксированным выходом, 100 мА, 15 В / LDO
Datasheet LM78L05, LM78L09, LM78L12, LM78L15, LM78L62, LM78L82
1.0 Мб, Файл закачен: 2 дек 2019, Страниц: 21
LM78LXX Series 3-Terminal Positive Regulators
51 предложений от 31 поставщиков
Чип стабилизации напряжения, TEXAS INSTRUMENTS LM78L15ACM Linear Voltage Regulator, 7815, Fixed, Positive, 16.7V To 35V In, 15V And 0.1A Out, SOIC-8...
Элитан
LM78L15
9.84 ₽
LM78L15ACMX/NOPB
13 ₽
LM78L15ACZ
22 ₽
Контест
LM78L15F
58 ₽
  • AN-103 LM340 Series Three Terminal Positive Regulators (Rev. A)
    PDF, 814 Кб, Версия: A, Файл опубликован: 6 май 2013
    The LM340-XX are three terminal 1.0A positive voltage regulators with preset output voltages of 5.0V or15V. The LM340 regulators are complete 3-terminal regulators requiring no external components fornormal operation. However by adding a few parts one may improve the transient response provide for avariable output voltage or increase the output current. Included on the chip are all of t
  • Digital Designer's Guide to Linear Voltage Regulators & Thermal Mgmt (LDO) (Rev. A)
    PDF, 509 Кб, Версия: A, Файл опубликован: 4 июн 2008
  • Understanding the Terms and Definitions of LDO Voltage Regulators
    PDF, 197 Кб, Файл опубликован: 21 окт 1999
    This report provides an understanding of the terms and definitions of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current standby current efficiency transient response line/load regulation power supply rejection output noise voltage accuracy and power dissipation. Each section includes an example to increase the understandab
  • AN-1148 Linear Regulators: Theory of Operation and Compensation (Rev. B)
    PDF, 300 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses the operation and compensation of linear regulators.
  • TO-92 Packing Options / Ordering Instructions (Rev. A)
    PDF, 287 Кб, Версия: A, Файл опубликован: 23 июн 2010
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
  • Semiconductors> Power Management> Linear Regulator (LDO)> Single Channel LDO
На английском языке: Datasheet Texas Instruments LM78L15
