Datasheet Texas Instruments LM94022 — Даташит
СерияLM94022
В±1.5В°C Temperature Sensor with Multiple Gain and Class-AB Analog Output
LM94022/-Q1 1.5-V, SC70, Multi-Gain Analog Temperature Sensor With Class-AB Output datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 29 сен 2015
LM94022BIMGLM94022BIMG/NOPBLM94022BIMGX/NOPB
Статус продуктаНе рекомендуется для новых разработокВ производствеВ производстве
Доступность образцов у производителяНетДаДа
N123
Pin555
Package TypeDCKDCKDCK
Industry STD TermSOT-SC70SOT-SC70SOT-SC70
Package QTY100010003000
CarrierLARGE T&RLARGE T&RLARGE T&R
Маркировка22B22B22B
Width (мм)1.251.251.25
Length (мм)222
Thickness (мм).9.9.9
Pitch (мм).65.65.65
Max Height (мм)1.11.11.1
Parameters / ModelsLM94022BIMG
LM94022BIMG
LM94022BIMG/NOPB
LM94022BIMG/NOPB
LM94022BIMGX/NOPB
LM94022BIMGX/NOPB
InterfaceAnalog OutputAnalog OutputAnalog Output
Local Sensor Accuracy(Max), +/- C1.51.51.5
Рабочий диапазон температур, Cот -50 до 150от -50 до 150от -50 до 150
Output Impedance, Ohm5.25.25.2
Package GroupSC70SC70SC70
Package Size: mm2:W x L, PKG5SC70: 4 mm2: 2.1 x 2(SC70)5SC70: 4 mm2: 2.1 x 2(SC70)5SC70: 4 mm2: 2.1 x 2(SC70)
RatingCatalogCatalogCatalog
Sensor Gain, mV/Deg C-5.5 to -13.6-5.5 to -13.6-5.5 to -13.6
Special FeaturesSelectable gain settingSelectable gain settingSelectable gain setting
Supply Current(Max), uA8.18.18.1
Supply Voltage(Max), В5.55.55.5
Supply Voltage(Min), В1.51.51.5
RoHSSee ti.comСовместимСовместим
  • AN-1952 Designing with Thermocouples (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 7 май 2013
    In 1821 Thomas Seebeck discovered the physical phenomenon that when you join two dissimilar metalson both ends and heat one end, a continuous current is created in the thermoelectric circuit . If the otherend is broken, a voltage can be measured that is proportional to the temperature difference between theheated junction (measuring or hot junction) and the open end (reference or cold ju
  • Low-Voltage Current Loop Transmitter
    PDF, 519 Кб, Файл опубликован: 2 авг 2007
  • Semiconductors> Sensing Products> Temperature Sensors> Local Analog Temperature Sensors
На английском языке: Datasheet Texas Instruments LM94022
