Datasheet Texas Instruments LM94022-Q1 — Даташит
СерияLM94022-Q1
Automotive Grade, В±1.5В°C Temperature Sensor with Multiple Gain and Class-AB Analog Output
LM94022/-Q1 1.5-V, SC70, Multi-Gain Analog Temperature Sensor With Class-AB Output datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 29 сен 2015
LM94022QBIMG/NOPBLM94022QBIMGX/NOPB
Доступность образцов у производителяДаНет
N12
Pin55
Package TypeDCKDCK
Industry STD TermSOT-SC70SOT-SC70
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY10003000
CarrierLARGE T&RLARGE T&R
Маркировка22Q22Q
Width (мм)1.251.25
Length (мм)22
Thickness (мм).9.9
Pitch (мм).65.65
Max Height (мм)1.11.1
Parameters / ModelsLM94022QBIMG/NOPB
LM94022QBIMG/NOPB
LM94022QBIMGX/NOPB
LM94022QBIMGX/NOPB
InterfaceAnalog OutputAnalog Output
Local Sensor Accuracy(Max), +/- C1.51.5
Рабочий диапазон температур, Cот -50 до 150от -50 до 150
Output Impedance, Ohm5.25.2
Package GroupSC70SC70
Package Size: mm2:W x L, PKG5SC70: 4 mm2: 2.1 x 2(SC70)5SC70: 4 mm2: 2.1 x 2(SC70)
RatingAutomotiveAutomotive
Sensor Gain, mV/Deg C-5.5 to -13.6-5.5 to -13.6
Special FeaturesSelectable gain settingSelectable gain setting
Supply Current(Max), uA8.18.1
Supply Voltage(Max), В5.55.5
Supply Voltage(Min), В1.51.5
RoHSСовместимСовместим
  • AN-1952 Designing with Thermocouples (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 7 май 2013
    In 1821 Thomas Seebeck discovered the physical phenomenon that when you join two dissimilar metalson both ends and heat one end, a continuous current is created in the thermoelectric circuit . If the otherend is broken, a voltage can be measured that is proportional to the temperature difference between theheated junction (measuring or hot junction) and the open end (reference or cold ju
  • Low-Voltage Current Loop Transmitter
    PDF, 519 Кб, Файл опубликован: 2 авг 2007
Серия: LM94022-Q1 (2)
  • Semiconductors> Sensing Products> Temperature Sensors> Local Analog Temperature Sensors
На английском языке: Datasheet Texas Instruments LM94022-Q1
Публикации по теме
