Datasheet Texas Instruments LM95233 — Даташит
СерияLM95233
В±2В°C Dual Remote and Local Temperature Sensor with TruTherm Technology and SMBus Interface
Dual Remote Diode and Local Temp Sensor w/SMBus I/F and TruTherm Technology datasheet
PDF, 1.2 Мб, Версия: E, Файл опубликован: 22 мар 2013
LM95233CISDLM95233CISD/NOPBLM95233CISDX/NOPB
Статус продуктаНе рекомендуется для новых разработокВ производствеВ производстве
Доступность образцов у производителяДаНетНет
N123
Pin141414
Package TypeNHLNHLNHL
Industry STD TermWSONWSONWSON
JEDEC CodeS-PDSO-NS-PDSO-NS-PDSO-N
Package QTY100010004500
CarrierSMALL T&RSMALL T&RLARGE T&R
Маркировка95233CI95233CI95233CI
Width (мм)444
Length (мм)444
Thickness (мм).8.8.8
Pitch (мм).5.5.5
Max Height (мм).8.8.8
Parameters / ModelsLM95233CISD
LM95233CISD
LM95233CISD/NOPB
LM95233CISD/NOPB
LM95233CISDX/NOPB
LM95233CISDX/NOPB
InterfaceI2C,SMBusI2C,SMBusI2C,SMBus
Local Sensor Accuracy(Max), +/- C222
Рабочий диапазон температур, Cот -40 до 140от -40 до 140от -40 до 140
Package GroupWSONWSONWSON
Package Size: mm2:W x L, PKGSee datasheet (WSON)See datasheet (WSON)See datasheet (WSON)
RatingCatalogCatalogCatalog
Remote Channel222
Remote Diode Temp Range for Listed Accuracy, C60 to 10060 to 10060 to 100
Remote Sensor Accuracy(Max), +/- C0.8750.8750.875
Remote Sensor CorrectionOffset Correction RegisterOffset Correction RegisterOffset Correction Register
Remote Temp Resolution(Max), bits131313
Special FeaturesOne shot conversion control,Programmable Alert,Programmable conversion rate,Remote diode fault detection,Shutdown,Thermal diode input stage filteringOne shot conversion control,Programmable Alert,Programmable conversion rate,Remote diode fault detection,Shutdown,Thermal diode input stage filteringOne shot conversion control,Programmable Alert,Programmable conversion rate,Remote diode fault detection,Shutdown,Thermal diode input stage filtering
Supply Current(Typ), uA570570570
Supply Voltage(Max), В3.63.63.6
Supply Voltage(Min), В333
Temp Resolution(Max), bits111111
RoHSSee ti.comСовместимСовместим
  • Semiconductors> Sensing Products> Temperature Sensors> Remote / Multi-channel Temperature Sensors
На английском языке: Datasheet Texas Instruments LM95233
