Datasheet Texas Instruments LM95235-Q1 — Даташит
СерияLM95235-Q1
Automotive Grade, В±2В°C Remote and Local Temperature Sensor with TruTherm Technology and SMBus
LM95235/235Q Precision Remote Diode Temp Sensor w/SMBus Intrface & TruTherm datasheet
PDF, 1.1 Мб, Версия: F, Файл опубликован: 22 мар 2013
LM95235QEIMMLM95235QEIMM/NOPBLM95235QEIMMX/NOPB
Статус продуктаНе рекомендуется для новых разработокВ производствеВ производстве
Доступность образцов у производителяНетДаНет
N123
Pin888
Package TypeDGKDGKDGK
Industry STD TermVSSOPVSSOPVSSOP
Package QTY100010003500
CarrierSMALL T&RSMALL T&RLARGE T&R
Маркировка36QE36QE36QE
Width (мм)333
Length (мм)333
Thickness (мм).97.97.97
Pitch (мм).65.65.65
Max Height (мм)1.071.071.07
Parameters / ModelsLM95235QEIMM
LM95235QEIMM
LM95235QEIMM/NOPB
LM95235QEIMM/NOPB
LM95235QEIMMX/NOPB
LM95235QEIMMX/NOPB
InterfaceI2C,SMBusI2C,SMBusI2C,SMBus
Local Sensor Accuracy(Max), +/- C222
Рабочий диапазон температур, Cот -40 до 85от -40 до 85от -40 до 85
Package GroupVSSOPVSSOPVSSOP
Package Size: mm2:W x L, PKG8VSSOP: 15 mm2: 4.9 x 3(VSSOP)8VSSOP: 15 mm2: 4.9 x 3(VSSOP)8VSSOP: 15 mm2: 4.9 x 3(VSSOP)
RatingAutomotiveAutomotiveAutomotive
Remote Channel111
Remote Diode Temp Range for Listed Accuracy, C60 to 10060 to 10060 to 100
Remote Sensor Accuracy(Max), +/- C0.750.750.75
Remote Sensor CorrectionBeta Compensation,TruThermBeta Compensation,TruThermBeta Compensation,TruTherm
Remote Temp Resolution(Max), bits131313
Special FeaturesOne shot conversion control,Programmable Alert,Programmable conversion rate,Remote diode fault detection,Shutdown,Thermal diode input stage filteringOne shot conversion control,Programmable Alert,Programmable conversion rate,Remote diode fault detection,Shutdown,Thermal diode input stage filteringOne shot conversion control,Programmable Alert,Programmable conversion rate,Remote diode fault detection,Shutdown,Thermal diode input stage filtering
Supply Current(Typ), uA350350350
Supply Voltage(Max), В5.55.55.5
Supply Voltage(Min), В2.72.72.7
Temp Resolution(Max), bits111111
RoHSSee ti.comСовместимСовместим
  • TruTherm Technology Presentation
    PDF, 170 Кб, Файл опубликован: 23 май 2006
  • Semiconductors> Sensing Products> Temperature Sensors> Remote / Multi-channel Temperature Sensors
На английском языке: Datasheet Texas Instruments LM95235-Q1
Публикации по теме
