Datasheet Texas Instruments LMH0036SQE/NOPB — Даташит
СерияLMH0036
МодельLMH0036SQE/NOPB
Реклокер SD SDI с входным мультиплексором 4:1 48-WQFN от -40 до 85
LMH0036 SD SDI Reclocker with 4:1 Input Multiplexer datasheet
PDF, 777 Кб, Версия: B, Файл опубликован: 15 апр 2013
Pin48
Package TypeRHS
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаXL036
Width (мм)7
Length (мм)7
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
ESD HBM8 kV
FunctionReclocker
In / Out count4/2
Max Data Rate270 Mbps
Package GroupWQFN
Package Size: mm2:W x L48WQFN: 49 mm2: 7 x 7(WQFN) PKG
Напряжение питания3.3 В
  • Reference Clock Loop Through Application
    PDF, 488 Кб, Файл опубликован: 16 янв 2009
  • AN-2145 Power Considerations for SDI Products (Rev. B)
    PDF, 63 Кб, Версия: B, Файл опубликован: 26 апр 2013
    This application report discusses the issues and trade-offs that VCC ripple has on the performance of SDI components.
  • Replacing the CLC014 Adaptive Cable Equalizer with the LMH0074 (Rev. A)
    PDF, 82 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report discusses the process to replace the CLC014 adaptive cable equalizer with the LMH0074 adaptive cable equalizer.
  • High-Speed Board Layout Challenges in FPGA/SDI Sub-Systems
    PDF, 427 Кб, Файл опубликован: 12 ноя 2009
  • Replacing the CLC012 Adaptive Cable Equalizer with the LMH0074 (Rev. A)
    This application report discusses the process of replacing the CLC012 adaptive cable equalizer with the LMH0074 adaptive cable equalizer.
  • AN-1943 Understanding Serial Digital Video Bit Rates (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 26 апр 2013
    The objective of this application report is to explain the basis for the bit rates used in serial digital interface (SDI). This leads to a deeper intuitive understanding of the nature of the SDI signal and will ultimately help the engineer design robust serial digital video systems.
  • AN-2146 Power Design for SDI and Other Noise-Sensitive Devices (Rev. A)
    PDF, 1.4 Мб, Версия: A, Файл опубликован: 26 апр 2013
    This application report discusses various solutions for meeting the power requirements of serial digital interface (SDI) video components.
Серия: LMH0036 (1)
  • LMH0036SQE/NOPB
  • Semiconductors > Interface > SDI > SDI Cable Equalizers, Drivers, Reclockers, and Cross-Points
На английском языке: Datasheet Texas Instruments LMH0036SQE/NOPB
