Datasheet Texas Instruments LMH0040SQE/NOPB — Даташит
Серия | LMH0040 |
Модель | LMH0040SQE/NOPB |
Сериализатор и драйвер HD, SD, DVB-ASI SDI с интерфейсом LVDS 48-WQFN от -40 до 85
LMH0340/040/070/050 3Gbps, HD, SD, DVB-ASI SDI Serializr & Cable Drvr w/LVDS I/F datasheet
PDF, 917 Кб, Версия: I, Файл опубликован: 16 апр 2013
![]() 30 предложений от 16 поставщиков Чип интерфейса, HD, SD, DVB-ASI SDI Serializer and Driver with LVDS Interface 48-WQFN -40℃ to 85℃ | |||
LMH0040SQE/NOPB Texas Instruments | 1 795 ₽ | ||
LMH0040SQE/NOPB Texas Instruments | 1 946 ₽ | ||
LMH0040SQE/NOPB Texas Instruments | 2 642 ₽ | ||
LMH0040SQE/NOPB Texas Instruments | по запросу |
Pin | 48 |
Package Type | RHS |
Industry STD Term | WQFN |
JEDEC Code | S-PQFP-N |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | LMH0040 |
Width (мм) | 7 |
Length (мм) | 7 |
Thickness (мм) | .75 |
Pitch (мм) | .5 |
Max Height (мм) | .8 |
Mechanical Data | Скачать |
Control Interface | Pin/SMBus |
Function | Serializer |
Тип входа | LVDS |
Max Data Rate | 1485 Mbps |
Тип выхода | 1 diff |
Package Group | WQFN |
Package Size: mm2:W x L | 48WQFN: 49 mm2: 7 x 7(WQFN) PKG |
Power Consumption | 440 mW |
Power Consumption(Typ) | 440 mW |
Special Features | Cable Driver |
Напряжение питания | 2.5,3.3 В |
Supply Voltage(Typ) | 2.5,3.3 В |
- AN-2145 Power Considerations for SDI Products (Rev. B)PDF, 63 Кб, Версия: B, Файл опубликован: 26 апр 2013
This application report discusses the issues and trade-offs that VCC ripple has on the performance of SDI components. - High-Speed Board Layout Challenges in FPGA/SDI Sub-SystemsPDF, 427 Кб, Файл опубликован: 12 ноя 2009
- AN-1943 Understanding Serial Digital Video Bit Rates (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 26 апр 2013
The objective of this application report is to explain the basis for the bit rates used in serial digital interface (SDI). This leads to a deeper intuitive understanding of the nature of the SDI signal and will ultimately help the engineer design robust serial digital video systems. - AN-1988 LMH0340 / LMH0341 SerDes Family LVDS Timing Overview (Rev. A)PDF, 56 Кб, Версия: A, Файл опубликован: 26 апр 2013
This application report discusses the LVDS timing requirements for the LMH0340 and LMH0341 family of products. - A 3 Gbps SDI Connectivity Solution Supporting Uncompressed 1080p60 VideoPDF, 2.9 Мб, Файл опубликован: 18 мар 2008
- AN-2146 Power Design for SDI and Other Noise-Sensitive Devices (Rev. A)PDF, 1.4 Мб, Версия: A, Файл опубликован: 26 апр 2013
This application report discusses various solutions for meeting the power requirements of serial digital interface (SDI) video components.
Серия: LMH0040 (2)
- LMH0040SQE/NOPB LMH0040SQX/NOPB
- Semiconductors > Interface > SDI > SDI SerDes
