Datasheet Texas Instruments LMH0387SLE/NOPB — Даташит
СерияLMH0387
МодельLMH0387SLE/NOPB
Адаптивный кабельный эквалайзер/драйвер кабеля ввода-вывода HD/SD SDI 3 Гбит/с 48-TLGA
LMH0387 3 Gbps HD/SD SDI Configurable I/O Adaptive Cable Equalizer / Cable Driver datasheet
PDF, 3.4 Мб, Версия: H, Файл опубликован: 31 авг 2015
Pin48
Package TypeNPD
Industry STD TermTLGA
JEDEC CodeS-PLGA-N
Package QTY250
CarrierSMALL T&R
МаркировкаLMH0387SL
Width (мм)7
Length (мм)7
Thickness (мм).8
Pitch (мм).5
Max Height (мм).9
ESD HBM6 kV
FunctionConfig I/O
In / Out count1/1
Max Data Rate2970 Mbps
Package GroupTLGA
Package Size: mm2:W x L48TLGA: 49 mm2: 7 x 7(TLGA) PKG
Напряжение питания3.3 В
  • Evaluation Modules & Boards: SD387EVK
    3 Gbps HD SD SDI Configurable I O Adaptive Cable Equalizer Cable Driver Evaluation Board
  • Evaluation Modules & Boards: ALP
    Analog LaunchPad Framework Utility
  • AN-2145 Power Considerations for SDI Products (Rev. B)
    PDF, 63 Кб, Версия: B, Файл опубликован: 26 апр 2013
    This application report discusses the issues and trade-offs that VCC ripple has on the performance of SDI components.
  • High-Speed Board Layout Challenges in FPGA/SDI Sub-Systems
    PDF, 427 Кб, Файл опубликован: 12 ноя 2009
  • AN-1943 Understanding Serial Digital Video Bit Rates (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 26 апр 2013
    The objective of this application report is to explain the basis for the bit rates used in serial digital interface (SDI). This leads to a deeper intuitive understanding of the nature of the SDI signal and will ultimately help the engineer design robust serial digital video systems.
  • AN-2146 Power Design for SDI and Other Noise-Sensitive Devices (Rev. A)
    PDF, 1.4 Мб, Версия: A, Файл опубликован: 26 апр 2013
    This application report discusses various solutions for meeting the power requirements of serial digital interface (SDI) video components.
  • AN-2156 Configuring the LMH0387 for an Equalizer-Only Application (Rev. A)
    This application note discusses how to configure the LMH0387 for an equalizer-only application.
Серия: LMH0387 (2)
  • Semiconductors > Interface > SDI > SDI Cable Equalizers, Drivers, Reclockers, and Cross-Points
На английском языке: Datasheet Texas Instruments LMH0387SLE/NOPB
