Datasheet Texas Instruments LMH1980MMX/NOPB — Даташит
| Серия | LMH1980 |
| Модель | LMH1980MMX/NOPB |
Автоматическое определение разделителя синхронизации видео SD/HD/PC 10-VSSOP от -40 до 85
LMH1980 Auto-Detecting SD/HD/PC Video Sync Separator datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 15 мар 2013
Купить LMH1980MMX/NOPB на РадиоЛоцман.Цены — от 66 до 385 ₽14 предложений от 14 поставщиков IC VIDEO SYNC 10VSSOP. Video IC 10-VSSOP Package. Linear - Video Processing | |||
| LMH1980MMX/NOPB National Semiconductor | 177 ₽ | ||
| LMH1980MMX/NOPB Texas Instruments | 212 ₽ | ||
| LMH1980MMX/NOPB Texas Instruments | 213 ₽ | ||
| LMH1980MMX/NOPB Texas Instruments | по запросу | ||
| Pin | 10 |
| Package Type | DGS |
| Industry STD Term | VSSOP |
| JEDEC Code | S-PDSO-G |
| Package QTY | 3500 |
| Carrier | LARGE T&R |
| Маркировка | AL4A |
| Width (мм) | 3 |
| Length (мм) | 3 |
| Thickness (мм) | 1.02 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.07 |
| Mechanical Data | Скачать |
| Control Interface | Pin |
| Formats Supported | NTSC,SECAM,SD/PC bi-level and HD tri-level,720p,1080i/p,PC Sync on Green (VESA),576i/p,480i/p |
| Function | Sync Separator |
| Package Group | VSSOP |
| Package Size: mm2:W x L | 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
| Power Consumption | 35 mW |
| Напряжение питания | 3.3,3.3 to 5 В |
- Evaluation Modules & Boards: LMH1980MMEVAL
Evaluation Board for LMH1980
- AN-1681 Design Migration from the LM1881 to the LMH1980 (Rev. A)PDF, 79 Кб, Версия: A, Файл опубликован: 3 май 2013
The LMH1980 is a SD/HD/PC video sync separator intended to replace the LM1881 sync separator inconsumer, security and surveillance, and industrial video applications where high-definition compatibility isneeded. This application report discusses the LMH1980’s advantages over the LM1881 andconsiderations for designing the LMH1980 into current LM1881 sockets. In broadcast and professionalvid - LMH1980 Sync Separator Design Considerations in Cable Hot-Plug ApplicatioPDF, 281 Кб, Файл опубликован: 27 мар 2016
In a video receiver, a sync separator’s function is to recover the sync timing embedded in an analog videosignal and output the sync pulses to the timing subsystem. This allows the timing subsystem to lock orsynchronize its local timebase to the recovered sync pulses so it can reliably capture, process, display,and/or re-transmit the incoming video data. The LMH1980 is a sync separator devic
Серия: LMH1980 (2)
- LMH1980MM/NOPB LMH1980MMX/NOPB
- Semiconductors > Interface > SDI > SDI Video Timing
