Datasheet Texas Instruments LMH1981MT/NOPB — Даташит
СерияLMH1981
МодельLMH1981MT/NOPB
Многоформатный разделитель видеосинхронизации 14-TSSOP от -40 до 85
LMH1981 Multi-Format Video Sync Separator datasheet
PDF, 1.3 Мб, Версия: H, Файл опубликован: 15 мар 2013
Pin1414
Package TypePWPW
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9494
CarrierTUBETUBE
МаркировкаLMH1981MT
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Control InterfacePin
Formats SupportedSD bi-level and HD tri-level sync,NTSC,720p,1080i/p,576i/p,480i/p,PAL
FunctionSync Separator
Package GroupTSSOP
Package Size: mm2:W x L14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
Power Consumption30 mW
Напряжение питания3.3,3.3 to 5 В
  • Evaluation Modules & Boards: LMH1981MTEVAL
    Evaluation Board for the LMH1981 Multi-Format Video Sync Separator
  • Evaluation Modules & Boards: ML571-1982CLK
    High-Performance SMPTE Video Clock Module for Xilinx ML571 Serial Digital Video Board
  • AN-1681 Design Migration from the LM1881 to the LMH1980 (Rev. A)
    PDF, 79 Кб, Версия: A, Файл опубликован: 3 май 2013
    The LMH1980 is a SD/HD/PC video sync separator intended to replace the LM1881 sync separator inconsumer, security and surveillance, and industrial video applications where high-definition compatibility isneeded. This application report discusses the LMH1980’s advantages over the LM1881 andconsiderations for designing the LMH1980 into current LM1881 sockets. In broadcast and professionalvid
  • Triple Rate SDI IP FPGA Resource Utilization on SDXILEVK/AES-EXP-SDI-G Ref Dsgn (Rev. A)
    PDF, 50 Кб, Версия: A, Файл опубликован: 26 апр 2013
    Texas Instruments triple rate (SD/HD/3G) SDI demonstration board showcases the LMH0340 serializer,LMH0341 deserializer, LMH0344 equalizer, LMH1981 sync separator, LMH1982 clock generator withgenlock and the DS25CP104 cross-point switch. There are many advantages to using the TexasInstruments chipset that include superior performance, reduced cost using inexpensive FPGAs such asthe Xilinx S
  • Demonst SMPTE-Compliant SDI Out Jittr Using LMH1982 & Virtx-5 GTP Xmittr (Rev. A)
    PDF, 3.1 Мб, Версия: A, Файл опубликован: 26 апр 2013
    As 3-Gbps serial digital interface (SDI) gains adoption in professional and broadcast video equipment to enable fast-frame 1080p HD video over a single link, the need for flexible and high-performance video clock generation becomes critical to reliably transmit and receive triple-rate (3G/HD/SD) SDI video. This is especially true for multi-channel video equipment using SDI serializers and deserial
  • Timing is Everything ‚Çô The Broadcast Video Signal Path
    PDF, 539 Кб, Файл опубликован: 2 авг 2007
  • A 3 Gbps SDI Connectivity Solution Supporting Uncompressed 1080p60 Video
    PDF, 2.9 Мб, Файл опубликован: 18 мар 2008
Серия: LMH1981 (2)
  • Semiconductors > Interface > SDI > SDI Video Timing
На английском языке: Datasheet Texas Instruments LMH1981MT/NOPB
