Datasheet Texas Instruments LMK02000ISQX/NOPB — Даташит
СерияLMK02000
МодельLMK02000ISQX/NOPB
Прецизионный распределитель тактовых импульсов со встроенной системой ФАПЧ 48-WQFN от -40 до 85
LMK02000 Precision Clock Conditioner with Integrated PLL datasheet
PDF, 826 Кб, Версия: D, Файл опубликован: 4 сен 2007
Микросхема Деталь тактового сигнала, Clock Synthesizer / Jitter Cleaner Precision Clock Distributor with Integrated PLL 48-WQFN -40℃ to 85℃
Hi-Tech Circuit Group
LMK02000ISQX/NOPB
LifeElectronics
LMK02000ISQX/NOPB
727GS
LMK02000ISQX/NOPB
LMK02000ISQX/NOPB
Pin48
Package TypeRHS
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY2500
МаркировкаK02000 I
Width (мм)7
Length (мм)7
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Input LevelLVCMOS,LVDS,LVPECL
Количество выходов8
Output Frequency(Max)800 МГц
Output LevelLVDS
Package GroupWQFN
Package Size: mm2:W x L48WQFN: 49 mm2: 7 x 7(WQFN) PKG
ProgrammabilityuWire
Special FeaturesDesign Tool Available
VCC Core3.3 В
VCC Out3.3 В
  • Selecting Amplifiers, ADCs, and Clocks for High-Performance Signal Paths
    PDF, 545 Кб, Файл опубликован: 13 сен 2007
  • AN-1821 CPRI Repeater System (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 26 апр 2013
    This application report implements the Common Public Radio Interface (CPRI) for Remote Radio Heads(RRHs). The designer can use this application report for developing CPRI-based repeater systems inpoint-to-point or multi-hop configurations. This application report consists of:Designs for the CPRI SerDes Repeater Boards for the Radio Equipment (RE) and Radio EquipmentController (REC)
  • Generating Precision Clocks for Time- Interleaved ADCs
    PDF, 680 Кб, Файл опубликован: 2 авг 2007
  • High Speed ADCs with Interfacing, Driving and Clocking Schemes (Rev. A)
    PDF, 178 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report discusses how the performance of high-speed pipeline ADCs can be optimized bydesigning the right clock circuitry, a good analog input network, as well as how to get the data at thesehigh speeds undistorted from the ADC onto an FPGA or ASIC.
  • AN-1734 Using the LMK03000C to Clean Recovered Clocks (Rev. B)
    PDF, 193 Кб, Версия: B, Файл опубликован: 26 апр 2013
    This application note delivers an example of how to clean recovered clocks, using the SCAN25100 SERDES and LMK03000C clock conditioner.
Серия: LMK02000 (2)
  • Semiconductors > Clock and Timing > Clock Generators > General Purpose
На английском языке: Datasheet Texas Instruments LMK02000ISQX/NOPB
