Datasheet Texas Instruments LMK03000ISQ/NOPB — Даташит
СерияLMK03000
МодельLMK03000ISQ/NOPB
Прецизионный преобразователь тактовых импульсов со встроенным ГУН 48-WQFN от -40 до 85
LMK03000 Family Precision Clock Conditioner with Integrated VCO datasheet
PDF, 1.1 Мб, Версия: O, Файл опубликован: 15 мар 2013
Pin48
Package TypeRHS
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаK03000 I
Width (мм)7
Length (мм)7
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Input LevelLVPECL, LVDS, LVCMOS
Количество выходов9
Output Frequency(Max)1570 МГц
Output Frequency(Min)0.29 МГц
Output LevelLVDS, LVPECL, RF
Package GroupWQFN
Package Size: mm2:W x L48WQFN: 49 mm2: 7 x 7(WQFN) PKG
ProgrammabilityuWire
Special FeaturesDesign Tool Available
VCC Core3.3 В
VCC Out3.3 В
  • Evaluation Modules & Boards: LMK03000CEVAL
    Precision Clock Conditioner with Integrated VCO (1185 - 1296 MHz)
  • AN-1865 Frequency Synthesis and Planning for PLL Architectures (Rev. C)
    PDF, 173 Кб, Версия: C, Файл опубликован: 26 апр 2013
    This application report demonstrates the importance of understanding the least common multiple (LCM) and greatest common divisor (GCD).
  • AN-1821 CPRI Repeater System (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 26 апр 2013
    This application report implements the Common Public Radio Interface (CPRI) for Remote Radio Heads(RRHs). The designer can use this application report for developing CPRI-based repeater systems inpoint-to-point or multi-hop configurations. This application report consists of:Designs for the CPRI SerDes Repeater Boards for the Radio Equipment (RE) and Radio EquipmentController (REC)
  • Phase Synchronization with Multiple Devices and Frequencies (Rev. A)
    PDF, 199 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application note discusses how phase synchronization can be achieved when multiple chips are involved and also when the frequencies are not the same.
  • Generating Precision Clocks for Time- Interleaved ADCs
    PDF, 680 Кб, Файл опубликован: 2 авг 2007
  • High Speed ADCs with Interfacing, Driving and Clocking Schemes (Rev. A)
    PDF, 178 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report discusses how the performance of high-speed pipeline ADCs can be optimized bydesigning the right clock circuitry, a good analog input network, as well as how to get the data at thesehigh speeds undistorted from the ADC onto an FPGA or ASIC.
  • AN-2006 Synchronizing a DP83640 PTP Master to a GPS Receiver (Rev. A)
    PDF, 35 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report discusses methods of synchronizing the precision time protocol (PTP) clock to aGPS receiver using the DP83640 precision PHYTERв„ў.
  • AN-1734 Using the LMK03000C to Clean Recovered Clocks (Rev. B)
    PDF, 193 Кб, Версия: B, Файл опубликован: 26 апр 2013
    This application note delivers an example of how to clean recovered clocks, using the SCAN25100 SERDES and LMK03000C clock conditioner.
  • Semiconductors > Clock and Timing > Clock Generators > General Purpose
На английском языке: Datasheet Texas Instruments LMK03000ISQ/NOPB
