Datasheet Texas Instruments LMK03328RHSR — Даташит
СерияLMK03328
МодельLMK03328RHSR
Семейство тактовых генераторов со сверхнизким джиттером и двумя независимыми системами ФАПЧ 48-WQFN от -40 до 85
LMK03328 Ultra-Low Jitter Clock Generator with Two Independent PLLs, Eight Outputs, Integrated EEPROM datasheet
PDF, 2.2 Мб, Версия: B, Файл опубликован: 24 авг 2016
Pin48
Package TypeRHS
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY2500
МаркировкаK03328A
Width (мм)7
Length (мм)7
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Input LevelCML,LVDS,LVPECL,XTAL
Количество выходов8
Output Frequency(Max)1000 МГц
Output LevelCML,HCSL,LVCMOS,LVDS,LVPECL
Package GroupWQFN
Package Size: mm2:W x L48WQFN: 49 mm2: 7 x 7(WQFN) PKG
ProgrammabilityEEPROM,I2C,Pin configuration
VCC Core3.3 В
VCC Out3.3,2.5,1.8 В
  • Evaluation Modules & Boards: LMK03328EVM
    LMK03328EVM Ultra-Low-Jitter Clock Generator EVM with 2 PLLs, 8 Differential Outputs, and 2 Inputs
  • Frequency Margining Using TI High-Performance Clock Generators (Rev. A)
    PDF, 1.0 Мб, Версия: A, Файл опубликован: 12 дек 2015
    Crystal oscillators and/or multiple output clock generators are critical in today’s high performance consumer, computing and communications systems. Deciding an optimal clock rate for the system can sometimes require several rounds of prototyping and validation. Clock Generator and Oscillator ICs with the right hooks to margin the synthesized clock can help to streamline the overall product develo
  • Clocking High Speed Serial Links with LMK033X8 (Rev. A)
    PDF, 1.7 Мб, Версия: A, Файл опубликован: 7 янв 2016
    This application report outlines the advantages of using ultra-high performance clock generators from Texas Instruments to generate system clocks needed for high-speed serial links. A methodology for deriving reference clock jitter requirements for high-speed Ethernet link is described, and the advantages of clocking such a system with the LMK03328 as opposed to discrete crystal oscillators are ou
  • Clocking for Medical Ultrasound Systems
    PDF, 1.8 Мб, Файл опубликован: 20 сен 2017
Серия: LMK03328 (2)
  • Semiconductors > Clock and Timing > Clock Generators > Ultra-Low Jitter <300fsec-RMS
На английском языке: Datasheet Texas Instruments LMK03328RHSR
