Datasheet Texas Instruments LMK61E2-SIAT — Даташит
СерияLMK61E2
МодельLMK61E2-SIAT
Полностью программируемый генератор со сверхнизким джиттером, встроенная EEPROM, +/-50ppm, 8-QFM, от -40 до 85
LMK61E2 Ultra-Low Jitter Programmable Oscillator With Internal EEPROM datasheet
PDF, 1.4 Мб, Версия: B, Файл опубликован: 3 фев 2017
Package TypeSIA
Industry STD TermQFM
JEDEC CodeR-PSIP-N
Package QTY250
CarrierSMALL T&R
МаркировкаLMK61E2
Width (мм)5
Length (мм)7
Thickness (мм).8
Pitch (мм)1.85
Max Height (мм)1.15
Additional Features7x5mm
Jitter0.1 ps
Output Frequency(Max)1000 МГц
Output LevelHCSL,LVDS,LVPECL
Pin/Package8QFM
Special FeaturesProgrammable with EEPROM
Stability50 ppm
VCC Core3.3 В
  • Evaluation Modules & Boards: LMK61E2EVM
    LMK61E2EVM Ultra-Low-Jitter Programmable Oscillator Evaluation Module
  • Time Domain Jitter Measurement Consideration for Low-Noise Oscillators
    PDF, 321 Кб, Файл опубликован: 5 окт 2015
    Phase Noise and Jitter are important metrics that describe the quality of a low-noise oscillator. Jitter is a time-domain representation of the timing accuracy of a signal and Phase Noise is the frequency domain representation of noise spectrum around the carrier tone. Equipment for measuring jitter in time-domain, such as real-time oscilloscopes, excel in their ability to directly measure period
  • Clocking for Medical Ultrasound Systems
    PDF, 1.8 Мб, Файл опубликован: 20 сен 2017
  • Frequency Margining Using TI's High Performance Programmable Oscillators
    PDF, 871 Кб, Файл опубликован: 2 окт 2015
    Crystal oscillators and/or multiple output clock generators are critical in today’s high performance consumer, computing, and communications systems. Deciding an optimal clock rate for the system can sometimes require several rounds of prototyping and validation. Clock Generators and Oscillator ICs - with the right hooks to margin synthesized clocks - can help to streamline the overall product dev
  • Vibration and Shock Sensitivity: A Comparative Study of Oscillators
    PDF, 2.8 Мб, Файл опубликован: 11 янв 2017
    When designing a system that incorporates a clock oscillator, the vibration sensitivity of the oscillatordevice is a specification that is easily overlooked. Sensitivity to vibration can have a detrimental impact onthe overall system performance. Since crystal oscillators fundamentally rely on the vibration andmechanical resonance of a piezoelectric material, external disturbances can couple
  • Semiconductors > Clock and Timing > Clock Oscillators
LMK61E2SIAT, LMK61E2 SIAT
На английском языке: Datasheet Texas Instruments LMK61E2-SIAT
